Forum Topic - QNX650: qcc (4.8.3) gives error while loading shared libraries (libstdc++.so.6):
I'm trying to use the current qcc compiler (4.8.3) for QNX650 on Linux. So far it's just extracting and copy/pasting.
But when I try to build my libraries I get the error msg:
i486-pc-nto-qnx6.5.0-g++: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such
file or directory
When I ldd on i486-pc-nto-qnx6.5.0-g++ then I get indeed
ldd /../qnx650/host/linux/x86/usr/bin/i486-pc-nto-qnx6.5.0-g++-4.8.3
	linux-gate.so.1 =>  (0xf7784000)
	libstdc++.so.6 => not found
	libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xf7721000)
	libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf7703000)
	libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xf7555000)
	/lib/ld-linux.so.2 (0xf7785000)
Apperently all the other libraries can be found.
What am I doing wrong and how can I resolve this?
Re: QNX650: qcc (4.8.3) gives error while loading shared libraries (libstdc++.so.6)
If you're running it on a 64bit system, the toolchain is built against
2bit libs? You might have to install the  libstdc++ i386 lib e.g.
sudo apt-get install lib32stdc++6 on ubuntu (or equivalent with other
distros/package managers)
Ryan Mansfield
such file or directory
> http://community.qnx.com/sf/go/post114030
> To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
.. good lord. I thought of everything but not that. Thanks a lot (also for this super quick reply), it's working now! I
tested everything and somehow I suspected something like this but I really thought I did install the 32bit libs already.
Check's in the mail! ;)
Thanks again.
