Forum Topic - Include<boost/shared_ptr> doesn't compile with QNX 6.6 QCC and c++11:
Hi QNX folks,
Using the std=c++11, QNX 6.6 QCC threw a compile error when I included boost/shared_ptr.
#include <boost/shared_ptr.hpp>
In file included from /home/test/qnx/ThirdParty/boost_1_55_0/boost/smart_ptr/detail/spinlock_sync.hpp:18:0,
                 from /home/test/qnx/ThirdParty/boost_1_55_0/boost/smart_ptr/detail/spinlock.hpp:41,
                 from /home/test/qnx/ThirdParty/boost_1_55_0/boost/smart_ptr/detail/spinlock_pool.hpp:25,
                 from /home/test/qnx/ThirdParty/boost_1_55_0/boost/smart_ptr/shared_ptr.hpp:38,
                 from /home/test/qnx/ThirdParty/boost_1_55_0/boost/shared_ptr.hpp:17,
                 from /home/test/qnx/TestProgram/math/math.cpp:5:
/home/test/qnx/ThirdParty/boost_1_55_0/boost/smart_ptr/detail/yield_k.hpp: In function 'void boost::detail::
yield(unsigned int)':
/home/test/qnx/ThirdParty/boost_1_55_0/boost/smart_ptr/detail/yield_k.hpp:122:29: error: 'nanosleep' was not declared in
 this scope
cc: /opt/qnx660/host/linux/x86/usr/lib/gcc/arm-unknown-nto-qnx6.6.0eabi/4.7.3/cc1plus error 1
make[2]: *** [TestProgram/math/CMakeFiles/testapp.math.dir/math.cpp.o] Error 1
make[1]: *** [TestProgram/math/CMakeFiles/testapp.math.dir/all] Error 2
Is this a boost issue or the QNX 6.6 toolchain issue?
Best regards,
Anton
Re: Include<boost/shared_ptr> doesn't compile with QNX 6.6 QCC and c++11
Did you solve this? I've encountered the same problem.
It seems like the toolset is linking to the Dinkum's time.h header:
http://www.qnx.com/developers/docs/660/topic/com.qnx.doc.dinkum/topic/cpp11/time.html
instead of the C Library's time.h:
http://www.qnx.com/developers/docs/660/topic/com.qnx.doc.neutrino.lib_ref/topic/n/nanosleep.html
Is it possible to link correctly without updating #include <time.h> using an absolute path instead.
When -std=c++11 is used it will enable __STRICT_ANSI__ causing us to disable extensions, like POSIX, in the headers.
nanosleep() is not part of C++11, so it will not be available when using this option.
You can use -std=gnu++11, or fiddle with the feature macros like _POSIX_C_SOURCE to enable the POSIX extensions and get
nanosleep() as expected.
Thanks!
I can now "successfully" build the boost libraries. The reason I put the successfully in quotations is because some of
the libraries doesn't seems to function as expected. When dynamically linking to for example the unit_test_framework,
its fine to build, but when I run the app I get a "Library cannot be found".
Checking for dependency on for example /libboost_unit_test_framework.so (using ldd) results in:
  libboost_unit_test_framework.so => /home/alex/qnx/660/bin/boost/libboost_unit_test_framework-qcc-mt-1_60.so.1.60.0
(0xb8200000)
ldd: Library cannot be found
It doesn't event say which library that couldn't be found... ?
I've cross-compiled boost using qcc 4.7.3.
Any thoughts? Thanks
Well that's not ideal.
Try running the unittests or ldd with the environment variable LD_DEBUG=libs. This will print some additional
information on libraries as they get loaded, and should at least print the name before hitting the failure.
I actually found the issue but I don't have a good solution (just a very awkward solution):
Doing an objdump on the unit-test-framework resulted in:
Dynamic Section:
   NEEDED               bin.v2\libs\timer\build\qcc\release\target-os-qnx\threadapi-pthread\threading-multi\
libboost_timer-qcc-mt-1_60.so.1.60.0
   NEEDED               bin.v2\libs\system\build\qcc\release\target-os-qnx\threadapi-pthread\threading-multi\
libboost_system-qcc-mt-1_60.so.1.60.0
   NEEDED               libm.so.2
   NEEDED               libc.so.3
As you can see there is a ridiculous path to link to both the timer and the system library. I've manually edited the
library's binary-file and removed the path (this is the awkward part...) to:
Dynamic Section:
   NEEDED               libboost_timer-qcc-mt-1_60.so.1.60.0
   NEEDED               libboost_system-qcc-mt-1_60.so.1.60.0
   NEEDED               libm.so.2
   NEEDED               libc.so.3
Which works. Is it possible to force Boost to not include the entire path into the library? Is this a boost issue or a
qcc toolchain issue? I really don't want to edit each library's binary file manually...
Hi Alexander,
Typically, that entire values can be solved by adding the following option to the linker
"-Wl,-rpath,$ORIGIN,-rpath,$ORIGIN/../lib".
If you use CMake:
set(CMAKE_EXE_LINKER_FLAGS "${CMAKE_EXE_LINKER_FLAGS} -Wl,-rpath,$ORIGIN,-rpath,$ORIGIN/../lib")
Hope this helps.
Two possibilities come to mind, the libraries so name is set incorrectly, or the soname is not set at all and the lib
was passed to the linker with the full path you are seeing.
You can use something like this to check what the soname is:
ntox86-readelf -d libboost_system-qcc-mt-1_60.so.1.60.0 | grep SONAME
Your build logs should show how things were passed to the linker, and whatever build system boost uses will hopefully
tell you why the options were used.
Some relevant links:
https://github.com/boostorg/build/issues/85
https://github.com/blackberry/Boost/issues/11
I ended up using a slightly simpler solution - simply adding a space
after $(HAVE_SONAME) seemed to resolve it for me.
-Will
diff --git a/src/tools/qcc.jam b/src/tools/qcc.jam
index 8edd995..d07ec74 100644
--- a/src/tools/qcc.jam
+++ b/src/tools/qcc.jam
@@ -235,5 +235,5 @@ rule link.dll ( targets * : sources * : properties * )
  actions link.dll bind LIBRARIES
-    "$(CONFIG_COMMAND)" -L"$(LINKPATH)" -Wl,-R$(SPACE)-Wl,"$(RPATH)" -o
"$(<)" $(HAVE_SONAME)-Wl,-h$(SPACE)-Wl,$(<[1]:D=) -shared "$(>)"
"$(LIBRARIES)" -l$(FINDLIBS-ST) -l$(FINDLIBS-SA) $(OPTIONS)
+    "$(CONFIG_COMMAND)" -L"$(LINKPATH)" -Wl,-R$(SPACE)-Wl,"$(RPATH)" -o
"$(<)" $(HAVE_SONAME) -Wl,-h$(SPACE)-Wl,$(<[1]:D=) -shared "$(>)"
> Dynamic Section:
>     NEEDED               libm.so.2
>     NEEDED               libc.so.3
> Dynamic Section:
>     NEEDED               libm.so.2
>     NEEDED               libc.so.3
> http://community.qnx.com/sf/go/post116343
> To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
