Forum Topic - Image building on IDE5.0 using SDP6.6:
    Hi:
    Some days before,I had updated my QNX6.5.1 to QNX6.6 and downloaded SDP6.6 from QNX BSP center,and I can build the
 SDP6.6 by default。And later I modified something in source code and rebuild,then I got a same image as the default
image, that means what I had modified was not linked。
    And I had added a make target in the related source with “install”, and ran “make install”, so I can saw the
file in install file had been changed,but when I right click the SDP to build project,I got the default image one
again。
  so how can I do to get a new image with something different with the default image?what configuration I should to do
 Thanks a lot!
