What is the process to install QNX 6.6.0 on the target?
03/19/2014 2:38 PM
post109513
What is the process for creating a QNX 6.6.0 target instance? This process appears to have changed since 6.5.0.
The quick start guide only explains how to use the provided VMware image, and "Building Embedded Systems" discusses
creating a BSP without explaining how to actually use it on a device. Setting up the SDP on the host was quite simple,
and there are clear instructions for this in several places.
What document or resource explains how to install QNX 6.6.0 on the target? Alternatively, what is the easiest way to set
up a QNX 6.6.0 target using the flash file system?
