Forum Topic - complex.h 4.7.2:
complex.h 4.7.2
6.6.0
Create a new QNX C++ project, remplace the content of the newly create .cc file with
#include <complex.h>
Compile.  I get:
d:/qnx660/target/qnx6/usr/include/complex.h:921:13: error: 'std::clog' has not been declared
Re: complex.h 4.7.2
On 14-03-07 06:03 PM, Mario Charest wrote:
> 6.6.0
> Compile.  I get:
Thanks for the report. I've filed issue # 627492 and will fix.
Ryan Mansfield
RE: complex.h 4.7.2
> -----Message d'origine-----
> De : Ryan Mansfield [mailto:community-noreply@qnx.com]
> Envoyé : 10 mars 2014 09:20
> À : general-toolchain@community.qnx.com
> Objet : Re: complex.h 4.7.2
> > 6.6.0
> file with
> > Compile.  I get:
> not been declared
Would you mind sharing the fix ?  Can`t use boost because of this.
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post109298
> To cancel your subscription to this discussion, please e-mail general-toolchain-
> unsubscribe@community.qnx.com
Re: complex.h 4.7.2
>>> 6.6.0
>> file with
>>> Compile.  I get:
>> not been declared
A quick fix would be to comment out line 921 of complex.h (e.g. using
std::clog) within the STD_USING block.
Ryan Mansfield
RE: complex.h 4.7.2
> Envoyé : 10 mars 2014 09:36
> >>> 6.6.0
> .cc
> >> file with
> >>> Compile.  I get:
> >> not been declared
When commented out, line 905 gives an error : unknown clog() I had to prefix clog() with ::
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post109300
RE: complex.h 4.7.2
> >>> 6.6.0
> .cc
> >> file with
> >>> Compile.  I get:
> >> not been declared
> Regards,
Another instance but this time with <complex>
#include <complex>
#include <boost/iterator/iterator_facade.hpp>
T:/opt/boost_1_55_0/boost/iterator/iterator_facade.hpp:43:19: error: expected ')' before numeric constant
T:/opt/boost_1_55_0/boost/iterator/iterator_facade.hpp:43:19: error: expected '>' before numeric constant
Cheers,
> Ryan Mansfield
Re: RE: complex.h 4.7.2
Sorry, rejoining the thread.
I will have to check but complex.h as per the standard  defines "I" which conflicts with Boosts using it as a template
parameter.
See boost bug:
https://svn.boost.org/trac/boost/ticket/8349
which they marked as wontfix..
Ryan Mansfield
RE: RE: complex.h 4.7.2
> Envoyé : 10 mars 2014 18:26
> Objet : Re: RE: complex.h 4.7.2
> conflicts with Boosts using it as a template parameter.
> See boost bug:
Ouch, note that I'm not using <complex*>, boost includes it on its own.  Hence I can't really do much about it.  I get
the error when doing #include <boost/lexical_cast.h>,
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post109322
Re: complex.h 4.7.2
I use SDP 660 to build one mature project. It reports the following error.
~/qnx660/target/qnx6/usr/include/complex.h:905:20: error: no match for call to '(std::ostream {aka std::basic_ostream<
char, std::char_traits<char> >})
in fact the clog function was regarded as iostream clog.  I don't know why SDP660 can have such bug.
Thanks/Zongjun
Re: complex.h 4.7.2
My code include boost file
                 from  include/boost/config/no_tr1/complex.hpp:21,
                 from include/boost/math/special_functions/math_fwd.hpp:30,
                 from include/boost/math/special_functions/sign.hpp:17,
                 from include/boost/lexical_cast.hpp:167,
                 from example.cpp:19:
Here is the code segment.
#include <iostream>
#include <boost/tokenizer.hpp>
#include <boost/lexical_cast.hpp>
#include <boost/ptr_container/ptr_vector.hpp>
#include <boost/shared_ptr.hpp>
The release version can be built successfully if I moved the iostream to the end. But the debug version still fails with
 the same error.
Hope it helps.
Zongjun
Re: complex.h 4.7.2
I reproduced this error as well using QNX SDP 6.6.
The error is as follows:
/opt/qnx660/target/qnx6/usr/include/complex.h: In function 'std::_Dcomplex std::log(std::_Dcomplex)':
/opt/qnx660/target/qnx6/usr/include/complex.h:905:20: error: no match for call to '(std::ostream {aka std::basic_ostream
<char, std::char_traits<char> >}) (std::_Dcomplex&)'
Is there any workaround or fix about this issue?
Best regards,
Anton
RE: complex.h 4.7.2
There is a patch available for QNX6.6.0 that addresses this problem. It is available on QNX`s web site.
De : Anton Indrawan [mailto:community-noreply@qnx.com]
Envoyé : 14 septembre 2014 09:39
Best regards,
Anton
General
http://community.qnx.com/sf/go/post111707
To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
Hi Mario,
The patch works well :)
Anton
Hi Mario,
SInce you did experience a problem with Boost as you mentioned on page 6 in this thread, I would like to know whether
you have a workaround or fix. At this moment, I applied the patch attached in https://svn.boost.org/trac/boost/ticket/
8349 and it works well, but I am wondering whether there is a real fix rather than changing the official Boost code.
Quote from page 6:
Thank you,
Anton
Re: complex.h 4.7.2
Hi Anton, Mario,
Please try with the attached header which doesn't define I within
__cplusplus to avoid collisions.
Ryan Mansfield
On 14-09-21 02:12 PM, Anton Indrawan wrote:
> Hi Mario,
> Quote from page 6:
> Thank you,
> Anton
> http://community.qnx.com/sf/go/post111799
Attachment: Text complex.h 23.66 KB
Re: complex.h 4.7.2
Hi Ryan,
Thanks for your reply. Yes, it is better than the patch attached to https://svn.boost.org/trac/boost/ticket/
8349.
Is your patch going to be released as an official QNX patch?
Best regards,
Anton
Re: complex.h 4.7.2
On 14-09-21 03:24 PM, Anton Indrawan wrote:
> Hi Ryan,
> 8349.
Yes, that's the plan.
Ryan Mansfield
Anton,
We use 4.8.3, it implies using gnu c++ lib instead of Dinkum,  the problem went away.
I realize 4.8.3 isn't officially supported by QNX, but what the hell, I don't mind living dangerously to move into the
year 2014 ( 4.7.2 is 2 years old), that's an editorial comment, lol!
Thanks for whom ever (Randy?) did the work to have 4.8.3 publish on Foundry,
Envoyé : 21 septembre 2014 14:13
Hi Mario,
Quote from page 6:
Thank you,
Anton
General
Re: RE: RE: complex.h 4.7.2
Hi Mario,
Using the GNU C++, I don't have this problem. Thanks to Ryan for the patch which works with the Dinkum one
Best regards,
Anton
Re: complex.h 4.7.2
See also:
--> http://www.qnx.com
--> Log on to myQNX (top right)
--> Click on "Download QNX 6.6.0" (near center of page)
--> Download "QNX® Software Development Platform 6.6 Header Files Patch [Patch ID 3851] "
