Re: does qnx use gnu glibc?
10/30/2013 2:17 PM
post106419
Have you set
QNX_TARGET and QNX HOST, it sounds like your build environment isn't set correctly.
Sent from my BlackBerry 10 smartphone.
Sent: Wednesday, October 30, 2013 18:18
To: general-toolchain
Reply To: general-toolchain@community.qnx.com
Subject: Re: RE: does qnx use gnu glibc?
Thank you,
I understand now,
I am trying to make a build environment on x86-linux platform to cross compile some open source packages to armv7-nto-
qnx. Since, I do not rebuild qnx compiler, and only use the downloaded toolchain along with native/target libraries
provided by this project, I do not have control for the linking process.
The problem i am having right now is that the binary tool (gcc), always want to load in c startup objects in armv7/armle
-v7/lib/crt1.o with a simple hello world program. That path was preconfigured while building the compiler for qnx. it
was probably defined using the preprocessor while building GCC:
#define STANDARD_STARTFILE_PREFIX "/some_cross_platform_library_path/lib/"
I would like to know if there is anyway I can modify the current precompiled linker (or linker script) to not search for
C-runtime (crt.o) in its standard location at armv7/armle-v7/lib/crt1.o. I tried telling the linker where to find the
c-runtime using -L -I search path arguments and the linker still error out, saying that path to object armv7/armle-v7/
lib/crt1* not found. Certainly, since I am making a build environment, i do not want to be in the target directory
where the linker can find its C-runtime library all the time.
Presently, I can only compile a hello world application under my development environment by telling gcc not to use its
linker script and c-runtime libraries by passing the following arguments.
ntoarmv7-gcc -nostdlib -L$root/usr/lib hello.c $root/usr/lib/armv7/armle-v7/lib/{crt*.o,libc.so.3}
This is only a work-around method. To have a truely cross platform toolchain, like the toolchain I made for arm-linux,
the linker must not always try to find its C-runtime library at a fixed location.
General
http://community.qnx.com/sf/go/post106418
To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
