Re: accelerate the compilation via multi-core machines
04/16/2008 3:17 AM
post6866
> Once upon a time I did manage to get distcc building the C library and it
> made a
> significant difference in time. It was a bit of a pain since I had to
> create a custom
> compiler configuration to front end for qcc but it did work.
> If someone is looking for a good summer coop project, resurecting distcc for
> qcc
> for QNX builds would be great for the community.
> Thomas
> On Tue, Apr 15, 2008 at 10:21 AM, Stephane Boucher <sboucher@qnx.com> wrote:
> > On Tue, 2008-04-15 at 09:07 -0400, Ryan Mansfield wrote:
> > > The compiler, assembler and linker are all single threaded
> > > applications so the answer is no. However someone with a
> > > multicore/multiprocessor system could use make to parallelize the
> > > build (make -j) which invokes the compiler several times
> > > simultaneously.
> > > http://www.gnu.org/software/make/manual/make.html#Parallel
> > Though a couple of things should be clarified:
> > 1) If you work with the qnx makefiles, you need to "make JLEVEL=4 all"
> > instead of "make -j 4 all".
> > 2) qnx makefiles have some bugs with regards to JLEVEL (the next release
> > will have the necessary fixes)
> > General
> > http://community.qnx.com/sf/go/post6800
Thanks all. Hi Thomas,
can perhaps You confrim that this is working (and if yes, will keep working)?:
http://lists.samba.org/archive/distcc/2006q3/003431.html
There we can read this:
We have distcc working with QNX 6.3.0 - the QNX cross-compiler 'qcc'
is more-or-less identical to gcc.
The main complication with QNX is its recursive makefile structure:
In order to use distcc you must edit c:/QNX630/target/qnx6/usr/include/qconfig.mk in
which 'make' variables are set up to invoke the various target-dependent compiler
derivatives. For example:
CC_nto_x86_gcc_qcc = $(QNX_HOST)/usr/bin/qcc -V$(gcc_ver_string)gcc_ntox86 -c
AS_nto_x86_gcc_qcc = $(QNX_HOST)/usr/bin/qcc -V$(gcc_ver_string)gcc_ntox86 -c
LR_nto_x86_gcc_qcc = $(QNX_HOST)/usr/bin/qcc -V$(gcc_ver_string)gcc_ntox86 -r
LD_nto_x86_gcc_qcc = $(QNX_HOST)/usr/bin/qcc -V$(gcc_ver_string)gcc_ntox86
AR_nto_x86_gcc_qcc = $(AR_nto_x86_gcc)
UM_nto_x86_gcc_qcc = $(UM_nto_x86_gcc)
LDBOOTSTRAP_nto_x86_gcc_qcc = $(LDBOOTSTRAP_nto_x86_gcc)
LDBOOTSTRAPPOST_nto_x86_gcc_qcc = $(LDBOOTSTRAPPOST_nto_x86_gcc)
must become:
CC_nto_x86_gcc_qcc = distcc qcc -V$(gcc_ver_string)gcc_ntox86 -c
AS_nto_x86_gcc_qcc = distcc qcc -V$(gcc_ver_string)gcc_ntox86 -c
LR_nto_x86_gcc_qcc = distcc qcc -V$(gcc_ver_string)gcc_ntox86 -r
LD_nto_x86_gcc_qcc = distcc qcc -V$(gcc_ver_string)gcc_ntox86
Then ensure that the PATH environment variable has c:/QNX630/host/win32/x86/usr/bin
early in its list. (N.B. QNX_HOST is set to c:/QNX630/host/win32/x86 on our
QNX distribution)
This works both from Momentics and a bash shell
In order to gain control of the 'make' -j option which QNX normally defaults to 1,
try 'make JLEVEL=2 CPULIST=<your target> ....' or add an equivalent build target to
Momentics.
Choosing '-j N' or JLEVEL=N where N is greater than the number of volunteer
hosts, we have found that distcc will occasionally cough out error message:
'cc: mkdir: cannot create temporary working directory'
'distcc[2024] ERROR: compile c:/tom/dick/harry.cpp failed'
Other than that, it seems to work as advertised. One is impressed.
Steven Whittard-Swift,...
