Re: gcc4.2.1 + T2 M6 issue with static linking (mcount missing)
04/11/2008 10:07 AM
post6673
> With the GCC 4.2.1 which was working 100% with 6.3.2a. Except for symlinks,
> the binutils and gcc look pretty solid.
> I loaded up the T2 M6 and now binaries with static linkage (-static) error
> with:
> LD platform/bin/symbols/embed
> libc.so: undefined reference to `_mcount_'
> I'll be darned if I can find mcount defined anywhere.
> NOTE: I am not compiled for gprof. I don't want gprof in my non-gprof
> binaries.
> The static libc in M6 definitely has no _mcount_:
> mcount.o:
> U _mcount_
> 00000000 T mcount
Yep it's missing. And the reason is how it's declared in profile.h
131 static void __attribute__ ((unused)) _mcount_ __P((uintfptr_t frompc, uintfptr_t selfpc));
The function should be declared with the used attribute so gcc 4.2 still emits the function. Since it's marked with
unused it only disables the warning but gcc removes it because it is declared static and has no references within the
translation unit. 6.3.2a, the libc was built with 2.95.3 which didn't optimize as aggressively.
The next milestone should contain _mcount_ but in the meantime you can make the change to the profile.h headers and
rebuild libc.
Ryan Mansfield
04/11/2008 1:39 PM
post6682
Ryan,
Thanks for the excellent reply. That explains it. And that 4.2.1 is *good*. The 2.95 emitted code looks like my hand
asm code (Jethro-dumb). The 4.2.1 register coloring/allocation, conditional load/store, branch-delay avoidance are like
nothing I could ever hand asm code.
However, we are really not a source customer. If we build source, it is under CM control (as opposed to install
control). Tweaking files not under CM is not in our plan. We *like* having libc be a "binary". :-)
I wanted to just use the M5 libc (pro-tem) but I am somewhat concerned because the M5 drop appears to have the same
issue. Perhaps it is too early for binary customers to migrate to 6.4.
Thanks again for your support.
dave
