Forum Topic - 4.8.1 and exception: (9 Items)
4.8.1 and exception
When building a simple program with the -Y_gpp option, exception aren't caught ???
Re: 4.8.1 and exception
I`m assuming Ryan is on holiday ;-) ?
I'm sure he will get back to you soon :-)
Ping.
Re-ping
Is there news on this issue? Stepping through the assembler I see that after a lot of looking for something to catch the
 exception, the code invariably terminates. Sample backtrace below:
        Thread [1] (Suspended: Signal 'SIGABRT' received. Description: Aborted.)
            8 SignalKill()  0xb033e2c1
            7 raise()  0xb032cf4e
            6 abort()  0xb032b248
            5 __gnu_cxx::__verbose_terminate_handler() ../../../../../libstdc++-v3/libsupc++/vterminate.cc:95 0xb8252265
            4 __cxxabiv1::__terminate() ../../../../../libstdc++-v3/libsupc++/eh_terminate.cc:38 0xb824fa15
            3 std::terminate() ../../../../../libstdc++-v3/libsupc++/eh_terminate.cc:48 0xb824fa6f
            2 __cxxabiv1::__cxa_throw() ../../../../../libstdc++-v3/libsupc++/eh_throw.cc:84 0xb824fcde
Are there missing pieces to this puzzle? compile flags, libs, or is this a known bug?
regards
George Refseth
the exception, the code invariably terminates. Sample backtrace below:
0xb8252265
Yes, it's a known issue. The unwinder needs to be able to find the
unwind information which means that all binaries  (exec and shared
libraries) need to use the same registration functions. With gcc 4.8,
the register function is now hidden so each binary gets it's own copy,
and the unwinder can't find it.  Emitting PT_GNU_EH_FRAME segments
should address this issue, but the unwind gear relies on
dl_iterate_phdr. However, dl_iterate_phdr isn't in 6.5.0. I've been
meaning to work on a solution for 6.5.0.
Ryan Mansfield
Hi Ryan,
Thanks for taking the time to post the details, I really appreciate the insight in to the source of the issue.  Should
we infer that even if there's no easy solution for 6.5.0, it will likely be working in the next QNX release?
-Will
On 14-02-10 12:28 PM, Will Miles wrote:
> Hi Ryan,
Yes, should be working in the next release. I've been meaning to look at
addressing the issue on 6.5.0, but haven’t had the time.
Ryan Mansfield
