Re: RE: How to enable support for Intel AVX?
06/14/2013 2:41 PM
post102330
> > > -----Message d'origine-----
> > > De : Ryan Mansfield [mailto:community-noreply@qnx.com]
> > > Envoyé : 13 juin 2013 10:48
> > > À : general-toolchain@community.qnx.com
> > > Cc : Igor Nikitin; Igor Nikitin
> > > Objet : Re: How to enable support for Intel AVX?
> > > On 13-06-13 10:46 AM, Igor Nikitin wrote:
> > > > Hello!
> > > > How do I enable support for Intel AVX on the system QNX 650SP1?
> > > I don't believe the 650SP1 kernel has support for AVX.
> > Hum if I recall from the early days of floating point, kernel support only
> > matter if you would be using these extra registered in more than one thread/
> > process.
> > Maybe it's an alignment issue or your processor doesn't support AVX. You
> need
> > sandybridge or better on Intel side. Bulldozer or better on the AMD side.
> > > Regards,
> > > Ryan Mansfield
> > > General
> > > http://community.qnx.com/sf/go/post102265
> > > To cancel your subscription to this discussion, please e-mail general-
> > > toolchain-unsubscribe@community.qnx.com
> I use Intel 3770k with microarchitecture Ivy Bridge. Earlier, I used Intel AVX
> on the Linux platform, all works well. Recently there appeared the necessity
> to work with register Intel AVX on QNX platform for developing real-time
> applications. The only thing I could achieve this error ' Illegal Instruction
> (core dump)".
Ryan was right, I came upon this in intel's doc:
"To use the Intel AVX extensions reliably in most settings, the operating system must support saving and loading the new
registers (with XSAVE/XRSTOR) on thread context switches to prevent data corruption. To help avoid such errors,
operating systems supporting Intel AVX-aware context switches explicitly set a CPU bit enabling the new instructions;
otherwise, an undefined opcode (#UD) exception is generated when Intel AVX instructions are used."
You could try to turn on that bit ( from in ISR cause I assume code must be running in ring 0 ). You would still be
limited to one thread using AVX extensions.
Hopefully a futur release of the OS will have AVX support.
