Forum Topic - Tracelogger Question: (8 Items)
We are using the tracelogger tool and would like to know if there are any know issue with the tool.
What we are seeing is, once you process the trace data we get inconsistant outputs in the data columb.  Sometimes the
data comes out as an integer, sometimes it comes out as a string.
here is the code fragment in question.
int count;
TraceEvent(_NTO_TRACE_INSERTSUSEREVENT, 81, count, 0);
Re: Tracelogger Question
In our mian we setup tracelogger with the following:
TraceEvent(_NTO_TRACE_ADDALLCLASSES);
TraceEvent(_NTO_TRACE_SETEVENTWIDE, _NTO_TRACE_KERCALL, __KER_SYNC_MUTEX_LOCK);
TraceEvent(_NTO_TRACE_SETEVENTWIDE, _NTO_TRACE_KERCALL, __KER_SYNC_MUTEX_REVIVE);
TraceEvent(_NTO_TRACE_SETEVENTWIDE, _NTO_TRACE_KERCALL, __KER_SYNC_MUTEX_UNLOCK );
TraceEvent(_NTO_TRACE_SETRINGMODE);   // use a ring buffer to overwrite old data with new
TraceEvent(_NTO_TRACE_START);         // begin tracing
Then we start the tracelogger with the following command line:
tracelogger -d2 -r -f
and yes we assign a value to the variable "count" before calling TraceEvent().
try -> tracelogger -d1. And what is version of qnx you use?????????????
Sorry we are using tracelogger -d1 - r -f, the d2 was a typo.
Check the link that I mentioned above (in the openqnx.com site).
> int count;
And I hope You assign value to the COUNT var before TraceEvent call.
The IDE will use a heuristic in the absence of a user event xml file,
based on whether it considers the user event data to be 'printable'.
Checkout the description in the ide docs on using an xml file to
describe the user event formats...
Cheers,
Colin
> int count;
> http://community.qnx.com/sf/go/post98465
> To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
cburgess@qnx.com
