How to generate a .ELF file.
12/17/2012 1:35 PM
post98172
I have an application that I can build and deploy under the Momentics debugger, the apps name is Feeder with no
extension. This works fine, I can run the debugger and do what I need to.
Now, I want to debug the same app only on the Lauterbach jtag debugger. According to there documention I need a debug
file in the .elf format. I would assume that all I should have to do is set a linker switch and that should be that.
According to the QNX documention It sounds like I need to rebuild the IPL and BSP in this format as well. My questions
are.
Can I just build my app in the .elf format or do I have to rebuild everything in that format?
What magic incantations are required to generate the .elf and were are the settings made in the IDE.
