Forum Topic - Timer quantization and cpu throttling: (4 Items)
Greetings fellows,
I have two rather nasty problems, both sort of connected to each other.
1) The first deals with the famous timer quantization problems. Following the QNX timer documentation, the smallest
quantization seems to be about 0.999847 or so milliseconds. For periododic timers/ triggers on integer millisecond base
this does not pose such a big problems, losing jsut about every 6300th timer or so. However, I need a way more accurate
timer to down to microseconds or, in other words, a trigger for instance every 7.333 milliseconds. I take it this will
not be working and implies (as our tests show) a catastrophic jitter? Please tell me I am mistaken :-)
2) Again for reasons of accuracy: Any way of knowing whether QNX disables CPU throttling or if not (what I do not expect
 for a real time OS) how to disable it?
Thanks a lot for help,
Andy
Re: Timer quantization and cpu throttling
I think toolchain forum is not the best place to ask this question. Try
OS forum
On 12-12-07 02:57 AM, Andreas Beschorner wrote:
> Greetings fellows,
expect for a real time OS) how to disable it?
> Andy
> http://community.qnx.com/sf/go/post97894
> To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
Andreas,
1)  QNX 6 doesn't have high resolution timers. AFAIK ... it's using the
IRQ 9 for its system tick.
2)  simply no
Regards
--Armin
> Greetings fellows,
> Andy
Thanks for the replies, however disappointing the facts are..
Problem resolved.
