Compiling Boost c++ library in Mementics in QNX
03/23/2008 6:57 AM
post6045
Actually we have to compile a program with Boost C++ in QNX(Gcc 2.95.3) using momentics.
We have downloaded Boost C++ version 1.34.1.
In QNX the Gcc version 2.95.3 is there along with QCC.
First we have installed Boost C++ by following the commands.
1) ./configure --with-toolset = gcc, and
2) make install
Some targets are skipped, some are not built and some more are built.
In Momentics IDE(with GCC 2.95.3), we wrote one sample program with Boost C++, while compiling, it took much time and
around 100 errors were there. These errors are from the Boost C++ library.
We wrote a small program as follows
<boost/filesystem.hpp>
int main ()
return 0;
We set the "extra include path" in the compiler option in momentics as /usr/local/include/boost-1_34_1 where we have the
boost directory and in that we have the FileSystem.hpp file. Also in the boost directory we have the following
directory filesystem which contains the convenience.hpp and operations.hpp.
Kindly let us know if we are heading in the right direction. The errors and the console o/p are attached.
Lakshmi.
Re: Compiling Boost c++ library in Mementics in QNX
03/24/2008 1:29 PM
post6066
> momentics.
I believe Boost documents that gcc 3.x and newer is required. Try switching to the gcc 3.3.5 compiler.
I was able to compile your small testcase with 3.3.5.
Ryan Mansfield
03/24/2008 1:39 PM
post6067
> 2) make install
Is that --with-toolset=gcc or --with-toolset=qcc? I believe Boost has a special configuration for QNX that uses qcc.
Ryan Mansfield
03/24/2008 4:18 PM
post6073
> momentics.
> 2) make install
Hi Lakshmi,
By the way, how many targets were skipped for your build? When I built Boost it only skipped 8 and built/updated 1171
targets.
Please let me know if you run into any other problems with Boost. i think they're an excellent set of libraries and I'd
like to see them work well on QNX.
Ryan Mansfield
03/25/2008 5:06 AM
post6080
> > Hi,
> using
> > momentics.
> > 2) make install
> Hi Lakshmi,
> it only skipped 8 and built/updated 1171 targets.
> they're an excellent set of libraries and I'd like to see them work well on
> QNX.
> Regards,
> Ryan Mansfield
Hi Ryan,
Thanks for your response.
We have set default to Gcc3.3.5 by gcc -V3.3.5,gcc_ntox86 -set-default.
then configured the library by following :
1) ./configure --with-toolset=qcc
2) make install.
So thus around 30 targets are not built, around 80 targets skipped and more than 5000 are updated.
We built the same program in momentics after building the boost library with GCC 3.3.5. Instead of 100 errors now we are
getting only 20 errors.
We have attached the errors with this posting.
The momentics project settings are as given below
c++ extra include directories /usr/cln/include/boost-1_34_1
linker extra library path /usr/cln/lib
linker extra libraries libboost_filesystem-d.so
Lakshmi
03/25/2008 9:50 AM
post6097
> GCC 3.3.5. Instead of 100 errors now we are getting only 20 errors.
Can you attach the console output instead of the problems tab? The problems output is truncated and difficult to read.
The only problem I could properly identify from the output you attached was:
ld: cannot find -llibboost_filesystem-d.so Ex line 0 1206449011983 69
Try changing the name in extra libraries from libboost_filesystem-d.so to boot_filesystem-d. Then -lboost_filesystem-d
will be passed down to the linker, and the linker prepends lib to the archive being searched and appends .so and .a
looking for appropriate matching library. By default, linker will use the dynamic variant of the library. The way you
have it configured right now, the linker is searching for liblibboost_filesystem-d.so.so
Ryan Mansfield
03/26/2008 4:55 AM
post6126
> boot_filesystem-d. Then -lboost_filesystem-d will be passed down to the linker
> and .a looking for appropriate matching library. By default, linker will use
> the dynamic variant of the library. The way you have it configured right now,
> Regards,
> Ryan Mansfield
Hi Ryan,
The program is:
#include <cstdlib>
#include <iostream>
#include <boost/filesystem.hpp>
namespace fs = boost::filesystem;
int main(int argc, char *argv[])
fs::path pa("/aaa.xml");
if( !fs::exists(pa))
std::cout<<"File does not exist"<<endl;
else
std::cout<<"File exists"<<endl;
return EXIT_SUCCESS;
I changed the linker libraries from libboost_filesystem-d.so to boot_filesystem-d, and built the project.
In the first attempt of building, in console of Momentics, the make was successful , but shown 20 errors and 20
warnings in problem tab and when I ran the same program it has shown message "Errors exist in required project. Continue
launch?" , then clicked OK, and got the output as
"File does not exists"
and I built the project twice sequentially, then build successful and it shown no errors and warnings
Inspite of errors how can I able to run the program in the first attempt?
and How can I resolve those 20 errors?
Here I am attaching the console tab .
03/26/2008 10:52 AM
post6150
> with
> linker
> use
> > Regards,
> > Ryan Mansfield
> Hi Ryan,
> The program is:
> #include <cstdlib>
> #include <iostream>
> else
> successful , but shown 20 errors and 20 warnings in problem tab and when I ran
> Continue launch?" , then clicked OK, and got the output as
From the console log you posted, there are only 20 warnings, not errors which explains why you're able to execute your
program. It looks like the IDE error parser is getting confused and treating the template instantiation locations as
errors instead of being part of the signed/unsigned comparison warning. One thing you could try is using the -fmessage-
length=n option where n equals the number of characters. The default value for c++ is 72 characters; try specifying a
long limit and see if the IDE parsers the error message any better.
Can you also specify-Wno-sign-compare and rebuild to confirm there are actually 20 warnings, instead of 20 errors?
Ryan Mansfield
03/26/2008 10:56 AM
post6152
If you set -fmessage-length=0 it would not truncate at all. This is
recommended setting for 3.3.5.
You can launch program if build is failed, this is user preference, which
you can turn on/off.
03/27/2008 1:13 AM
post6181
Hi Ryan,
I changed the compiler Other options as
fmessage-length=0 -Wno-sign-compare,
now it is working with out any errors or warnings.
Thanks Ryan for the inputs.
Lakshmi.
