Re: Corrupted shared library list: 0x0 != 0x813e800
10/17/2012 11:31 AM
post96395
On 12-10-17 11:09 AM, Mario Charest wrote:
> When starting the debugger I get:
> warning: Corrupted shared library list: 0x0 != 0x813e800
You can ignore this one, it just a difference between how linux creates
its linked list and ours. I haven't removed the warning, but it's benign.
> warning: Could not load shared library symbols for 7 libraries, e.g. libPocoZip.so.1_4_2p_1.
> Use the "info sharedlibrary" command to see the complete listing.
> Do you need "set solib-search-path" or "set sysroot"?
> info sharedlibrary
> From To Syms Read Shared Object Library
> 0xb0300000 0xb037ee70 Yes C:/QNX650/target/qnx6/x86/usr/lib/ldqnx.so.2
> No libPocoZip.so.1_4_2p_1
> No libpartage.so
> 0xb8257000 0xb82891e0 Yes C:/QNX650/target/qnx6/x86/lib/libm.so.2
> 0xb828a000 0xb82b929c Yes C:/QNX650/target/qnx6/x86/lib/libsocket.so.3
> No libPocoFoundation.so.1_4_2p_1
> No libPocoXML.so.1_4_2p_1
> No libPocoNet.so.1_4_2p_1
> No libstd_c.so.5_650
> No libboost_serialization.so
> 0xb8379000 0xb83dec58 Yes C:/QNX650/target/qnx6/x86/lib/libcpp.so.4
> What to make of it?
For the rest, I'd suggest using .gdbinit file with set solib-search-path
to your paths wehre the above mentioned files are (e.g.
libPocoZip.so.1_4_20_1)
