Re: RE: 6.5.0 + SP1 + Ubuntu 10.4 32-bit: mkifs link broken
08/29/2012 10:15 AM
post95259
Natalia, Steve,
thanks you for your help. The problem is definitely not to do with" sudo -E" as I used that option. It turns out
something went wrong when installing SP1 on top of 6.5.0.
I did more research on this and it looks like 5.6.0 installs correctly. All files and tools are in place, I can
successfully build and make OS image.
Then after installing SP1 I'm getting those broken links mkifs etc links in /opt/qnx650/host/linux/x86/usr/bin/. And the
other thing I noticed is that files from /opt/qnx650/target/qnx6/armle-v7/boot/sys/* get wiped out too.
But the most interesting thing is the 4th cycle of full reinstall worked fine. Everything finally seems in tact, can
build and make images. I can't explain that though ... I used the suggested SP1 cleanup tool QNXLinuxCleanup every time
to tidy up.
