Forum Topic - No gcc on QNX 6.5.0??: (9 Items)
I am using a VMware image of QNX 6.5.0 with service pack 1  Runtime environment.
So I did a 'which gcc' in the terminal but it returned with a
"which: no gcc in ..."
Now normally should the gcc be in /usr/qnx630/host/qnx6/x86/usr/bin/gcc?
Because strangely, I do not have the directory /usr/qnx630/
Please help.
Re: No gcc on QNX 6.5.0??
Also, I tried 'which qcc'... but no qcc exists either.
You've installed the runtime image. If you want to do self-hosted x86
self hosted development, you need to install the Neutrino SDP host.
http://www.qnx.com/download/feature.html?programid=23654
Ryan Mansfield
> Regards,
> Ryan Mansfield
Yes, I do have an SDP, and I am running the IDE to write a simple hello world program. I've also connected to the target
 using the IDE (I've followed the steps found in "http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.
momentics_quickstart/about.html".
 However, when I try to run the program in the IDE, I am getting an error: "Error: Attempting to exec a shared lib"
I was speculating that the libc.so were not matching.
target using the IDE (I've followed the steps found in "http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.
qnx.doc.momentics_quickstart/about.html".
Can you paste the output of  ntox86-readelf -hd <exec>?
Ryan Mansfield
> world program. I've also connected to the target using the IDE (I've followed
> com.qnx.doc.momentics_quickstart/about.html".
> Regards,
> Ryan Mansfield
If you meant run that on the terminal on the target, it says I don't have the ntox86.
>> Regards,
>> Ryan Mansfield
On your development host.
Ryan Mansfield
/bin/sh: ntox86-readelf: cannot execute - No such file or directory
