Forum Topic - svn checkout fails:
svn checkout fails
I tried to check out the 650_release branch of the core utils today:
svn checkout --username guest --password "" http://community.qnx.com/svn/repos/core-dev-tools/tools/gcc/branches/
650_release
and got an error while checking out:
A    650_release/libjava/classpath/lib/javax/swing/JMenu$MenuChangeListener.class
svn: REPORT of '/svn/repos/core-dev-tools/!svn/vcc/default': 200 OK (http://community.qnx.com)
And the checkout did not finish. Googling suggests that this may be server side, and could be fixed with a svn server
restart.
Has anyone else bumped into this before? Any suggestions for a workaround?
Todd
RE: svn checkout fails
This sort of thing happens all the time (and seems to be worse over e.g. VPN; some reports suggest 1.7 clients are
unreliable as well).
If the checkout is at least partially complete, you should probably be able to do repeated "svn update"s until you
eventually get a full tree.
Sent: June-26-12 7:44 PM
To: general-toolchain
Subject: svn checkout fails
650_release
restart.
Todd
General
http://community.qnx.com/sf/go/post93886
To cancel your subscription to this discussion, please e-mail general-toolchain-unsubscribe@community.qnx.com
Re: RE: svn checkout fails
Okay, I will try updating and see if I eventually get a full checkout.
Todd
