connection to multiple target boards in target navigator?
03/10/2008 12:07 PM
post5652
Maybe I've missed something obvious...
For a new multi-processor design we were hoping to be able to access multiple targets from the target navigator.
As it is, in Momentics 4.0.1, the target navigator shows that the most recently plugged in target is connected. Once
this happens, connection to the previously connected target is lost. Clicking on the disconnected target name will not
restore communications. Only a disconnect and reconnect of the ethernet connection will make that target active again.
The targets have unique ip addresses and are on the same subnet.
I had expected that any one target would be accessible at any one time, and that each target would be selectable without
the unplug/replug routine as at present.
If anyone has experience of making this work any pointers would be much appreciated.
By the way, this is being done with an evaluation license. We have assumed that such a license is time-limited only and
not restricted in terms of functionality.
thanks in advance for any clues
Tim
