Forum Topic - i.MX31 build image won't build after installation of Trinity M4: (4 Items)
Win32 host, I installed the latest Trinity build per instructions.
The i.MX31 BSP was rebuilt with minor problems (struct _sync_attr field names changed with addition of leading
underscores which broke the i.mx31_devn-crys8900 driver, easily fixed).
However, now when trying to build the image an error is generated in the IDE that says "Unable to build path to mkifs.
exe". In the base directory c:\qnx630\host\win32\x86\usr\bin is a shortcut mkifs which seems to properly point to c:\
qnx630\host\win32\x86\usr\bin\mkxfs.exe which is a valid executable.
So, what is this obscure error trying to tell me? The build console output only says this:
Building Image: bsp-freescale_i.mx31
Build Failed.
The error in the Problems tab says this:
Unable to build path to mkifs.exe
The errors are less than helpful.
TIA
Re: i.MX31 build image won't build after installation of Trinity M4
It turns out I'm not sure if this is related to the Trinity M4 build or the 6.7 GDB release, because both of those were
installed on a previously working development environment, but the problem is apparently with the windows shortcuts that
 were created.
After installing both packages the mkifs.exe file was a shortcut to mkxfs.exe. That shortcut was not resolving. It
looked correct, but deleting it and creating a new shortcut also failed. Deleting the shortcut and copying mkxfs.exe to
mkifs.exe fixed the problem.
It appears that the mkefs.exe and mketfs.exe are also shortcuts to mkxfs.exe and those will probably fail too. I'm not
sure why they fail, the shortcut paths seem to be absolutely correct, but they do.
RE: i.MX31 build image won't build after installation of Trinity M4
> From: Ken Schumm [mailto:kwschumm@qsolv.com]
> Sent: Wednesday, March 05, 2008 11:11 AM
> To: general-toolchain
> Subject: Re: i.MX31 build image won't build after
It is highly unlikely it has to do with gdb 6.7 release, if you look in the
archived file you downloaded, you will see only gdb executables.
> were created.
> not sure why they fail, the shortcut paths seem to be
> http://community.qnx.com/sf/go/post5526
Re: RE: i.MX31 build image won't build after installation of Trinity
OK, I stand corrected. Both packages were installed without building the image in between so it wasn't clear exactly
when the problem appeared.
