Forum Topic - make causes multicore processor to freeze: (7 Items)
Hello all:
I am evaluating QNX6.5 and have ran into the first serious problem trying to use a multicore processor.  When I try to
build our product, which has several directory levels with hierarchical calls to "make", the system will lock up.   The
lock up always seems to occur on a "make clean".
The Makefiles are unchanged from QNX6.3, though some of the defines and directories are system dependent, so that is not
 as strong a statement as one would like.  The same command on the same computer booted with the qnxbase.ifs kernel (as
opposed to qnxbasesmp.ifs) will complete without freezing the system.  I have gotten this to happen doing a "make -n
clean", which suggests that the problem is in the evaluation of what needs to be done as opposed to actually doing it.
I have repeated the problem with another dual core computer, different manufacturer, different processor.  The problem
does not occur on a single core processor.
Has anyone seen this type of lock up?  Is there a work around or fix?
Mike Zeller
www.ansaldo-sts.com<http://www.ansaldo-sts.com>;
Re: make causes multicore processor to freeze
I heard about it, and I think Ryan had a fix in msys for this (or some?) lockup. Can you search forum for msys patches
and try to apply it?
On 12/14/2011 04:12 PM, Mike Zeller wrote:
> Hello all:
not as strong a statement as one would like.  The same command on the same computer booted with the qnxbase.ifs kernel
(as opposed to qnxbasesmp.ifs) will complete without freezing the system.  I have gotten this to happen doing a "make -n
> Thanks,
> Mike Zeller
> http://community.qnx.com/sf/go/post90632
RE: make causes multicore processor to freeze
Sound self- hosted so no msys there ;-)
-----Message d'origine-----
De : Elena Laskavaia [mailto:community-noreply@qnx.com]
Envoyé : 14 décembre 2011 16:26
À : general-toolchain
Objet : Re: make causes multicore processor to freeze
> Hello all:
> Thanks,
> Mike Zeller
General
http://community.qnx.com/sf/go/post90634
Elena, he's not using Windows. He said he's booting
qnxbase.ifs/qnxbasesmp.ifs which means he's running QNX Neutrino...
Mike, no, this is not a known issue.
Ryan Mansfield
Sorry I missed that. Could be some priority inversion related? We have weird priority thing going when building...
patches and try to apply it?
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post90636
Good day:
Here is some more information.  Yes, I am compiling on Neutrino.  The toolchain is what comes out of the box.
The freeze up does not always occur on a make clean.  my build script will do a "make clean" followed by a "make all".
Make clean just happened first.
The lockups occur at various stages in the process, but always in a transition into or out of a new directory, never
while "building".  That is, if make has 20 files to compile and link, the compile/link steps will complete without a
freeze up.  The freeze up will happen sometime in the transition from leaving one directory and entering the next
directory. The last line to print will always be "Make[n] Entering directory ...\n make ..." or "Make[m] Leaving
directory ..."
I have tried using "on -C 0 -i make <target>".  The freeze up will still occur.
I have tried adding -j 1 to the top level make.  The freeze up will still occur.
Mike
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: Wednesday, December 14, 2011 4:31 PM
To: general-toolchain
Subject: Re: make causes multicore processor to freeze
> Regards,
> Ryan Mansfield
General
http://community.qnx.com/sf/go/post90637
Re: RE: make causes multicore processor to freeze
I'm also evaluating QNX 6.5 SP1, and am seeing the same issues. Was this ever resolved?
