QNX 6.5 Static linking with libsocket crashes debugger
12/01/2011 12:41 PM
post90383
I have a project that uses a fully static link. The project runs fine on the target, but if I try to launch it with the
debugger, I get an error: Can't access memory at address 0x8144564.
If I dynamically link, the project launches fine via the debugger.
I need a fully static link for now because some of the targets do not have the newer libraries like libstdc++.so.16 (I'm
using GCC 4.6) and I don't have control over the targets.
I tried using the official QNX 6.5 setup w/GCC 4.3 and the same problem occurs. I did not try QNX 6.4.1.
I would really like to be able to debug and build with the same configuration.
Thanks in advance,
Dave.
