Forum Topic - Throw exception from shared object.: (4 Items)
I try to throw a C++ exception from a function located in a shared lib and catch it from my main thread.
But the only thing I get is a "core dumped" ...
my compiler version : 3.3.1 and my QNX core version :  6.3.0
Did anyone do  the same stuff ?
RE: Throw exception from shared object.
To this all the time and works fine, but I`m not using 6.3.0.
Did you add the compiler option to support exception,when building the shared lib and program?
> -----Message d'origine-----
> De : Philippe ELSKENS [mailto:community-noreply@qnx.com]
> Envoyé : 6 octobre 2011 10:26
> À : general-toolchain
> Objet : Throw exception from shared object.
> Hello,
> Thanks
> http://community.qnx.com/sf/go/post89245
Re: RE: Throw exception from shared object.
Thanks you Mario for your answer.
I don't know what kind of options are needed to use C++ exceptions in a shared lib.
I've tried -fexceptions but it seems that options is just need for C functions to work  with mixed C++.
It seems  the problem was : I linked my shared lib with qcc and not with QCC.
Some of my file are c file and other are c++ files. I always use qcc and it selects the good compiler with the extension
 of the files (c or cpp ).
But the problem appears  when I make the dynamic lib with the object files collection.
before (I get Abort and core dumped ) :
qcc -o mylib.so obj1.o obj2.o ....
now (it works fine):
QCC -o mylib.so obj1 obj2.o
Voilà.
