Forum Topic - Breakpoint confusion -- multiple processes: (3 Items)
I'm using IDE 4.7 with QNX 6.4.1
I'm debugging several processes at once.  If I set a breakpoint in process 'A' and then start process 'B", the
breakpoint in process 'A' is tagged with a warning 'Unresolved Breakpont'.  If process 'B' is stopped, then the tag is
removed.
One of the results of this happening is that I can't use conditional breakponts, the breakpoint is hit no matter what.
Also, sometimes if I remove the breakpoint, it is still hit.
Any insights, or things I could do to prevent the unresolved breakpoint issue?  I think this may solve problems I have
with conditional break points.
Kevin
Re: Breakpoint confusion -- multiple processes
Debugging is not very good with multiple processes. Breakpoint associated with the source code, not with process. So
when you create breakpoint it will be hit
if ANY of the processes have this code executed. So breakpoints kind of shared if one is not found in another process it
 would be mark as unresolved (but it would be hit in another one).
Anyway I suggest to use two IDE's instead.
removed.
> Thanks
> Kevin
> http://community.qnx.com/sf/go/post87145
Thanks...that insight is very helpful.  Conditional breakpoints actually started to work, so I'm happy.  But thanks for
clarifying how this works.  That is very helpful.
I hope you guys are doing well...take care,
Kevin
