Forum Topic - Video conference call application on QNX: (2 Items)
Hi All,
Anybody have any idea that s it feasible to create a video conference application on ANX OS. I am new in this OS and
want to develop the application.
Any help would be appreciated.
Re: Video conference call application on QNX
It is quite feasible and you have two general options:
1) Use the low level QNX graphics framework (GF)
2) Use the QNX composition manager which uses the higher level OpenKode API <== recommended
If you are starting from an existing video conferencing application you will likely use one of the two above options to
add a graphics backend so the application. If you are starting from scratch I recommend reading through the online
reference.
I copy below the links to the developer guides for the QNX Graphics framework and the Composition Manager. Read through
them to determine which is suitable to your needs.
The QNX Graphics Framework > Developer Guide:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.gf_dev_guide/about.html
QNX Neutrino Composition Manager > Developer's Guide:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.composition_manager_dev_guide/about.html
