Forum Topic - backslashes in binary name when invoking pidin: (5 Items)
Hi all,
I am noticing backslashes in my binaryname when invoking pidin. Example: c:\workspace\my_project\o_g\my_bin
This prevents 'slay' to kill the process. Can you tell me what I am missing?
TIA,
Freddy
Re: backslashes in binary name when invoking pidin
It's inserted by ldrel (which is invoked by usemsg).  This is fixed in the
head branch kernel.
You can remove it by stripping your binary (but that will also remove the
use message).  To
my knowledge if you use the objcopy argument to use then it will not add it
(since it is not
using ldrel)
Colin
Freddy Martens wrote:
Hi all,
TIA,
Freddy
General
http://community.qnx.com/sf/go/post4271
<http://community.qnx.com/sf/go/post4271>;
cburgess@qnx.com <mailto:cburgess@qnx.com>;
RE: backslashes in binary name when invoking pidin
Alternatively, I've made a small change to my qmacros.mk
(c:/QNX632/target/qnx6/usr/include/mk/qmacros.mk or whatever) to pass just
the file name and not the entire path to usemsg and this seems to avoid the
problem quite nicely.
Just change:
define ADD_USAGE
	$(if $(UMPREF),$(UMPREF) $(addprefix -i,$(tag_list))
$(ADD_VERSIONING) $@ $(USEFILE) $(UMPOST))
endef
to
define ADD_USAGE
$(ADD_VERSIONING) $(notdir $@) $(USEFILE) $(UMPOST))
Endef
Roger
Sent: January 14, 2008 11:59 AM
To: general-toolchain
Subject: Re: backslashes in binary name when invoking pidin
head branch kernel.
use message).  To my knowledge if you use the objcopy argument to use then
it will not add it (since it is not using ldrel)
Colin
Hi all,
TIA,
Freddy
General
General
http://community.qnx.com/sf/go/post4272
Re: RE: backslashes in binary name when invoking pidin
Thanks for the answer.
Freddy
It happens when I use the IDE and fill in the filename for the use message in the project properties.
Freddy
