Forum Topic - glibc-4.2 missing on RHEL 5.0 system:
I'm trying to use the QNX gcc 4.2.1 toolchain as downloaded from the website. It looks like the ppc assembler was linked
 against glibc-2.4 which our RHEL 5.x 32-bit systems do not have installed. Curiously, other bits of the toolchain
(preprocessor, cc1) work fine.
$ /scratch/qnx632/host/linux/x86/usr/bin/ntoppc-as-2.17
/scratch/qnx632/host/linux/x86/usr/bin/ntoppc-as-2.17: /lib/tls/libc.so.6: version `GLIBC_2.4' not found (required by /
scratch/qnx632/host/linux/x86/usr/bin/ntoppc-as-2.17)
I downloaded and built glibc-2.4, installing it off to the side; attempting to install glibc is almost always a bad idea
Setting LD_LIBRARY_PATH is insufficient to trick the dynamic linker into finding it. See strace output below.
Any idea how I can make the toolchain work without actually installing glibc-2.4?
Thanks... Dave Barach
$ strace /scratch/qnx632/host/linux/x86/usr/bin/ntoppc-as-2.17
execve("/scratch/qnx632/host/linux/x86/usr/bin/ntoppc-as-2.17", ["/scratch/qnx632/host/linux/x86/u"...], [/* 45 vars */
]) = 0
uname({sys="Linux", node="sw-eclipse-13", ...}) = 0
brk(0)                                  = 0x9ab8000
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/tls/i686/sse2/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/tls/i686/sse2", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/tls/i686/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/tls/i686", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/tls/sse2/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/tls/sse2", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/tls/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/tls", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/i686/sse2/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/i686/sse2", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/i686/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/i686", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/sse2/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib/sse2", 0xbfe23e20) = -1 ENOENT (No such file or directory)
open("/scratch/dbarach/glibc/glibc-2.4/lib/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/scratch/dbarach/glibc/glibc-2.4/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/etc/ld.so.cache", O_RDONLY)      = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=75160, ...}) = 0
old_mmap(NULL, 75160, PROT_READ, MAP_PRIVATE, 3, 0) = 0xb7fed000
close(3)                                = 0
open("/lib/tls/libc.so.6", O_RDONLY)    = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\316"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1454802, ...}) = 0
old_mmap(0x6d8000, 1223900, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x6d8000
old_mmap(0x7fd000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x124000) = 0x7fd000
old_mmap(0x801000, 7388, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x801000
close(3)                                = 0
writev(2, [{"/scratch/qnx632/host/linux/x86/u"..., 53}, {": ", 2}, {"/lib/tls/libc.so.6", 18}, {": ", 2}, {"version `
GLIBC_2.4\' not found (r"..., 97}, {"\n",...
Re: glibc-4.2 missing on RHEL 5.0 system
Hey Dave,
Thanks for pointing out that the binutils were linked against a newer glibc. We really shouldn't be doing that since not
 all of our supported hosts use glibc 2.4. I'll post a set of packages linked against an older glibc as soon as possible
I think our build of gcc/binutils is actually less complicated than the build of glibc, so if you feel so inclined you
could build the binutils/gcc and install them over top of the existing package which contain the target libs and qcc
conf files for 4.2.1.
Ryan Mansfield
Thanks very much.  Please ping me via unicast e-mail when the rebuilt gcc/binutils pkgs are available.
