Re: RE: Problem placing breakpoints using GDB 6.7
02/12/2008 1:54 PM
post4952
Aleksandar,
Yes we're using the latest gdb6.7 from Foundry 27. I have not yet been
able to create a small test case. A simple hello world type application
works fine. It seems to only be an issue with our larger complex projects.
I will continue to try and create a test case.
-Keith
> Are you using gdb6.7 downloaded from Foundry 27?
> Could you create a small sample code that demonstrates the problem?
> Thanks,
> Aleksandar
> > From: Keith Weatherly [mailto:kweatherly@google.com]
> > Sent: December 17, 2007 9:07 PM
> > To: general-toolchain
> > Subject: Problem placing breakpoints using GDB 6.7
> > When trying to place breakpoints in GDB 6.7 i'm getting a message saying
> > 'GDB does not support pointers to methods on this target'. This seems to
> > occur when placing breakpoints on C++ member functions. A breakpoint on
> > main() works fine.
> > Has anyone seen this before?
> > Thanks
> > General
> > http://community.qnx.com/sf/go/post3858
