Queries related to IO-Audio
11/03/2010 1:22 AM
post73393
I have following queries related to IO-Audio component present in the BSP package provided by QNX for Mistral
Omap3530EVM.
1. Does the software mixer present in IO-Audio has sample rate converter also ?
2. In the .build file I could see that the IO-Audio is invoked with 'omap35xx-twl4030' driver, How can I disable the
mixer and hence the sample rate converter module ?
I have tried invkoing the IO-Audio with'-o disable_sw_mixer' option but if I play 16KHz file it still plays properly and
hence I conclude that the option did not make any difference in the behaviour(As I unerstand the ound card supports
only 44.1KHz & 48KHZ and hence there will be a sample rate conversion from 16 to 48 KHz).
Please let me know your comments as it is quite important for me.
