Forum Topic - _ecpp-ne: (2 Items)
_ecpp-ne
On 6.5.0 from command line I type
QCC -Y _ecpp-ne -lang-c++ -fno-exceptions -I/usr/qnx650/target/qnx6/usr/include/cpp  stdafx.cpp -c -o stdafx.o
With
===== begin of stdafx.cpp =====
#include <stl.h>
===== end of stdafx.cpp =====
And I get the following errors
===== Begin of output =====
$ QCC -Y _ecpp-ne -lang-c++ -fno-exceptions -I/usr/qnx650/target/qnx6/usr/include/cpp  stdafx.cpp -c -o stdafx.o
In file included from /usr/qnx650/target/qnx6/usr/include/cpp/xmemory:9,
                 from /usr/qnx650/target/qnx6/usr/include/cpp/memory:7,
                 from /usr/qnx650/target/qnx6/usr/include/cpp/algorithm:6,
                 from /usr/qnx650/target/qnx6/usr/include/cpp/stl.h:26,
                 from stdafx.cpp:1:
/usr/qnx650/target/qnx6/usr/include/cpp/xutility:1258: error: expected type-specifier before 'char_traits'
/usr/qnx650/target/qnx6/usr/include/cpp/xutility:1258: error: expected '>' before 'char_traits'
/usr/qnx650/target/qnx6/usr/include/cpp/xutility:1259: error: redefinition of default argument for 'class _Traits'
/usr/qnx650/target/qnx6/usr/include/cpp/iosfwd:449: note: original definition appeared here
/usr/qnx650/target/qnx6/usr/include/cpp/xutility:1410: error: invalid use of template-name 'std::char_traits' without an
 argument list
/usr/qnx650/target/qnx6/usr/include/cpp/xutility: In member function 'std::ostreambuf_iterator<_Elem, _Traits>& std::ostreambuf_iterator<_Elem,
_Traits>::operator=(_Elem)':
/usr/qnx650/target/qnx6/usr/include/cpp/xutility:1441: error: 'traits_type' has not been declared
In file included from /usr/qnx650/target/qnx6/usr/include/cpp/stl.h:29,
                 from stdafx.cpp:1:
/usr/qnx650/target/qnx6/usr/include/cpp/iterator: At global scope:
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:171: error: expected type-specifier before 'char_traits'
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:171: error: expected '>' before 'char_traits'
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:174: error: '_Diff' was not declared in this scope
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:174: error: template argument 4 is invalid
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:176: error: '_Diff' was not declared in this scope
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:176: error: template argument 4 is invalid
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:177: error: '_Diff' was not declared in this scope
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:177: error: wrong number of template arguments (4, should be 3)
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:173: error: provided for 'template<class _Ty, class _Elem, class
_Traits> class std::istream_iterator'
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:181: error: '_Mybase' is not a class or namespace
/usr/qnx650/target/qnx6/usr/include/cpp/iterator: In member function 'bool std::istream_iterator<_Ty, _Elem, _Traits>::
_Equal(const int&) const':
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:247: error: request for member '_Myistr' in '_Right', which is of non-class type 'const int'
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:267: error: wrong number of template arguments (4, should be 3)
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:173: error: provided for 'template<class _Ty, class _Elem, class _Traits> class std::istream_iterator'
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:268: error: wrong number of template arguments (4, should be 3)
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:268: error: 'bool std::operator==(const int&, const int&)' must have an
 argument of class or enumerated type
/usr/qnx650/target/qnx6/usr/include/cpp/iterator:278: error: wrong number of template...
Re: _ecpp-ne
You guys should be aware that when you are making links from /usr/include into $QNX_TARGET/usr/include there CAN BE
other files, not only *.h and *.c. And that is related to both GNU's and Dincimware's STLs. And that is far not the
first OS release you forget to link files like that.
And for Dincumware's STL there are even compiler warnings from new GCC not fixed which indicates that nobody ever tested
 it for long long time.
