Forum Topic - Destructor segfault in armle-v7 cpp shared objects: (3 Items)
I am encountering an issue and have provided a test case.
If I have a armle-v7 shared object that I load and unload with dlopen/dlclose that contains any sort of global object
with a destructor, I get a seg fault after the dlclose.  The exact same code works fine on an 6.5 armle system.
The attached code and project have two different example that don't work, and one that does (where the destructor is
removed).  atexit used in the so constuctor instead of a destructor also fails.
Complete code for shared object:
class SimpleClass
public:
	SimpleClass() {};
	~SimpleClass() {};
static SimpleClass gSimpleClass;
Complete code for executable linking .so above:
#include <dlfcn.h>
#include <iostream>
int main(int argc, char *argv[])
   void* pSimple = dlopen("/tmp/libsimple_g.so.1", RTLD_NOW );
   if( pSimple )
	   int returnVal = dlclose( pSimple );
	   std::cerr << "dlclose return value = " <<  returnVal << std::endl;
   else
	   std::cerr << "Unable to open simple" << std::endl;
   return 0;
Attachment: Compressed file CppSharedObjectIssue.zip 311.43 KB
Re: Destructor segfault in armle-v7 cpp shared objects
Yes, this is a bug. GA patch addressing this problem is coming out very
soon. I'll update this post when it becomes available.
Aleksandar
> dlopen/dlclose that contains any sort of global object with a
> work, and one that does (where the destructor is removed).  atexit
> class SimpleClass
> public:
>         SimpleClass() {};
>         ~SimpleClass() {};
> #include <dlfcn.h>
> #include <iostream>
>    if( pSimple )
> std::endl;
>    else
>    return 0;
> http://community.qnx.com/sf/go/post71351
Hello David,
GA patch that fixes this issue can be downloaded from here:
http://www.qnx.com/download/feature.html?programid=21666
Thank you,
Aleksandar
> Aleksandar
> > class SimpleClass
> > public:
> >         SimpleClass() {};
> >         ~SimpleClass() {};
> > #include <dlfcn.h>
> > #include <iostream>
> >    if( pSimple )
> > std::endl;
> >    else
> >    return 0;
> > General
