Forum Topic - optimization : # a C file within a C file : compiler question:
I need to understand how the compiler treats a C file #included inside of another C file.
Why does this result in Optimized code or does it ?
Preeti.
RE: optimization : # a C file within a C file : compiler question
C compiler gets preprocessed file from preprocessor. Preprocessor will
insert the #include file into the intermediate file that is fed to the
compiler. Therefore, when you include a .c file in another .c file, it gets
"inserted" into your compiled .c file.
This is a process that happens before compilation and therefore has no
effect on optimizations.
> From: Preeti Sharma [mailto:presharm@cisco.com]
> Sent: December 4, 2007 5:45 AM
> To: general-toolchain
> Subject: optimization : # a C file within a C file : compiler question
> another C file.
> Thanks
> Preeti.
> http://community.qnx.com/sf/go/post3283
Well, partly true.  The compiler cannot optimize accross object files.
Whereas it can optimize within an object file.  So, if you:
cat *.c >big.c
and compile big.c, then you may get more optimized code than if you
compile all the .c files seperately.
Re: RE: optimization : # a C file within a C file : compiler question
> cat *.c >big.c
gcc 4.x driver has a -combine option to do just that.
Ryan Mansfield
Thanks for the details ...
I have seen that when such files (the C files that are included within another C file) are compiled with optimization -
O3 ; I do not see a bt of the functions in included C file ....
What exactly is happening there ?
Preeti
>  C file) are compiled with optimization -O3 ; I do not see a bt of the
As Alek explained, the #included c file gets preprocessed into one translation unit which is then compiled. This means
the #include'd C file is compiled with the same options as the file that includes it.
Ryan Mansfield
Yes I understand that but that should still allow me to see a bt. If within a <big.c> file I have f1() and f2() one
calling the other; I should see them in the bt.
irrespective of which C file they belonged to when they were compiled ...
Thanks ...
>  file I have f1() and f2() one calling the other; I should see them in the bt.
If you are compiling everything with -O3, then the functions are probably being inlined which is why they do not appear
in the backtrace.
Ryan Mansfield
True that is what I suspect too but why are they being inlined if "I do not say inline " and all the preprocessor does
is create a <big.c> from 2 C files ...
Does that mean that all the functions in the included C file are implicitly inlined ...
Preeti.
> say inline " and all the preprocessor does is create a <big.c> from 2 C files ...
> inlined ...
Not all, but it will implicitly inline functions at -O3. Which options are you using to disable inlining? -fno-inline
and -fno-inline-functions?
Ryan Mansfield
Re: RE: optimization : # a C file within a C file : compiler ques tion
See:
http://gcc.gnu.org/onlinedocs/gcc-4.1.2/gcc/Optimize-Options.html#Optimize-Options
-finline-functions
        Integrate all simple functions into their callers. The compiler
        heuristically decides which functions are simple enough to be
        worth integrating in this way.
        If all calls to a given function are integrated, and the
        function is declared static, then the function is normally not
        output as assembler code in its own right.
        Enabled at level -O3.
hmm ok so not inly __inline__ functions but other functions "deemed simple" by the compiler can be inlined too ...
So to summarize:  when I say  #include a C file; since both the functions are now in the same <big.c> file the compiler
can take the liberty to "inline" one into the other while it might be unable to do so if they reside in different C
files ...
Preeti.
The __inline__ tag is merely a hint.  It indicates that the author believes the function to be a good candidate for in-
lining.
Generally compilers treat hints from authors in much the same way that baggage handlers treat a package with the label "
fragile"; so it is quite likely that the compiler will not inline some of the functions you tagged with __inline__, and
may, in fact, inline every function except the ones that you tagged (perhaps out of spite :-).
Re: optimization : # a C file within a C file : compiler ques tion
You can check what options are passed by adding -fverbose-asm and
generating an assembly file.
qcc -Vgcc_ntoarmle -S -fverbose-asm foo.c
you will see that there are two directives to do with inlining -finline
and -finline-functions
In fact, if you examine the output for O2 and O3 I believe the only
difference is -finline-functions
Colin
> do not say inline " and all the preprocessor does is create a <big.c>
> from 2 C files ...
> Thanks
> Preeti.
> http://community.qnx.com/sf/go/post3317
cburgess@qnx.com
