Mudflap related crash in static variable initialisation
09/20/2010 7:13 AM
post67833
I've just started trying to use mudflap on a QorIQ P2020 target (PPCBE-SPE) but it crashes, apparently while
initialising IOStreams/locale.
This is using the supplied 'hello world' C++ project.
From the stack trace, I'd also guess that it might be down to not linking the right library(s) but this is just the
standard supplied project in debug build with -mudflap and -lmudflap added to the compiler and linker options.
This is using the latest 6.5 release of Momentics (gcc 4.4.2).
Any idea what's wrong / missing?
Thread [1] (Suspended: Signal 'SIGABRT' received. Description: Aborted.)
15 SignalKill() 0xfe33f948
14 raise() 0xfe32ef74
13 abort() 0xfe32d05c
12 std::do_abort() 0xfe4cc434
11 std::terminate() 0xfe4cc3ec
10 __cxxabiv1::__unexpected() 0xfe4c4220
9 __cxa_call_unexpected() 0xfe4c35d8
8 std::locale::locale() 0xfe4dd5dc
7 std::ios_base::Init::Init() 0xfe4cf014
6 global constructors keyed to wiostrea.cpp() 0xfe4e16ec
5 __do_global_ctors_aux() 0xfe4fea18
4 _init() 0xfe4c15a8
3 init() 0xfe3422b8
2 ldd() 0xfe348c68
1 _start_() 0xfe340a28
