09/15/2010 3:03 AM
post67334
I have built the object files in EABI format using ARM compiler(RVDS) and linked using the linker provided by momentics.
While debugging I am getting the following error,
No symbol "Automotive" in current context.
No symbol "N_FRAMES_TO_PROCESS" in current context.
Die: DW_TAG_restrict_type (abbrev = 35, offset = 39530)
has children: FALSE
attributes:
DW_AT_type (DW_FORM_ref2) constant ref: 39526 (adjusted)
Dwarf Error: Cannot find type of die [in module C:\IOAMP_Neon\MainMixerTestApplication\MainMixerTestApplication_g_new.
exe]
info signal SIGSEGV
info signal SIGSEGV
Signal Stop Print Pass to program Description
SIGSEGV Yes Yes Yes Segmentation fault
