Re: Compiling core-dev-tools/tools/binutils/trunk
09/02/2010 2:27 PM
post65751
On 10-09-02 02:23 PM, Jerry Sui wrote:
> When compiling the binutils in NTO, I got the following errors:
> WARNING: `makeinfo' is missing on your system. You should only need it if
> you modified a `.texi' or `.texinfo' file, or any other file
> indirectly affecting the aspect of the manual. The spurious
> call might also be the consequence of using a buggy `make' (AIX,
> DU, IRIX). You might want to install the `Texinfo' package or
> the `GNU make' package. Grab either from any GNU archive site.
> make[4]: *** [bfd.info] Error 1
> make[4]: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/bfd/doc'
> Making info in po
> make[4]: Entering directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/bfd/po'
> ( if test 'x/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/../bfd/po' != 'x.'; then \
> posrcprefix='/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/../bfd/'; \
> else \
> posrcprefix="../"; \
> fi; \
> rm -f SRC-POTFILES-t SRC-POTFILES \
> && (sed -e '/^#/d' \
> -e '/^[ ]*$/d' \
> -e "s@.*@ $posrcprefix& \\\\@"< /work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-
> ntoppc/../bfd/po/SRC-POTFILES.in \
> | sed -e '$s/\\$//')> SRC-POTFILES-t \
> && chmod a-w SRC-POTFILES-t \
> && mv SRC-POTFILES-t SRC-POTFILES )
> ( rm -f BLD-POTFILES-t BLD-POTFILES \
> -e '/^[ ]*$/d' \
> -e "s@.*@ ../& \\\\@"< /work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/..
> /bfd/po/BLD-POTFILES.in \
> | sed -e '$s/\\$//')> BLD-POTFILES-t \
> && chmod a-w BLD-POTFILES-t \
> && mv BLD-POTFILES-t BLD-POTFILES )
> cd .. \
> && CONFIG_FILES=po/Makefile.in:po/Make-in \
> CONFIG_HEADERS= /bin/sh ./config.status
> config.status: creating po/Makefile.in
> config.status: executing depfiles commands
> config.status: executing libtool commands
> config.status: executing default-1 commands
> config.status: executing bfd_stdint.h commands
> config.status: executing default commands
> make[4]: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/bfd/po'
> make[4]: Nothing to be done for `info'.
> make[4]: Entering directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/bfd'
> make[4]: Nothing to be done for `info-am'.
> make[4]: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/bfd'
> make[3]: *** [info-recursive] Error 1
> make[3]: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc/bfd'
> make[2]: *** [all-bfd] Error 2
> make[2]: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc'
> make[1]: *** [all] Error 2
> make[1]: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc'
> make: *** [all] Error 2
> make: Leaving directory `/work/devtools/core-dev-tools/tools/binutils/trunk/nto-x86-o-ntoppc'
> Do I need to install texinfo? where can I get it?
Not unless you're modifying the docs... You're likely being tripped up
by the lexicographical check out of svn where the generated files get
older timestamps (e.g....
