Forum Topic - Undefined reference error:
1st scenario.
I am having 4 library projects and one application project. Application project is using all the 4 library files.
The libraries are BasicSignalProcessing, ePIAF, FileIO, MainMixer and application is MainMixerTestApplication.
1. ePIAF library project has the reference(Project References) on BasicSignalProcessing.
2. FileIO library project has the reference(Project References) on BasicSignalProcessing and ePIAF library project.
3. MainMixer library project has the reference(Project References) on BasicSignalProcessing and ePIAF library project.
4. MainMixerTestApplication application project has the reference(Project References) on BasicSignalProcessing, ePIAF,
FileIO and MainMixer library projects.
Individual libraries are getting built properly but MainMixerTestApplication is failing with error 'undefined reference
to ...'.
I have added the necessary include folders in search paths and I am linking the above libraries by including them in
'Properties->QNX C/C++ Project->Linker->Extra library paths'
Attached the build log for your reference.
Can anyone tell me what is the exact reason and how to get rid of this CRITICAL error ?
2nd scenario.
I have created a TestLib library project and TestMain application project where main function calls the TestLibProc
function implemented in the test library. In this also I am getting similar error even though I am including the library
 while linking and it is getting resolved only if I include the OBJ file(TestLib.o) in the linker(Same is not happening
in the 1st example as it is flashing an error in both MainMixer & MainMixerTestApplication). I feel including OBJ file
is a crude method.
Attachment: Text ErrorLog.txt 17.48 KB
Re: Undefined reference error
I have added the following command to in the 'other options' of the linker
'-Bstatic -lFileIO -lBasicSignalProcessing -lePIAF -lMainMixer -lm' and I am getting the below error :( ...
It is really IMPORTANT for us to get rid of these kind of errors ...
C:/ide-4.7-workspace/MainMixerTestApplication/private/exampleAppMainMixer.c:344: warning: 'fpOutName1' is used
uninitialized in this function
C:/ide-4.7-workspace/MainMixerTestApplication/private/exampleAppMainMixer.c:352: warning: 'fpOutName2' is used
C:/QNX650/host/win32/x86/usr/bin/rm -f  C:/ide-4.7-workspace/MainMixerTestApplication/arm/o-le-g/
MainMixerTestApplication_g
C:/QNX650/host/win32/x86/usr/bin/qcc -Vgcc_ntoarm -Wl,--no-keep-memory  -Bstatic -lFileIO -lBasicSignalProcessing -
lePIAF -lMainMixer -lm    -oC:/ide-4.7-workspace/MainMixerTestApplication/arm/o-le-g/MainMixerTestApplication_g
exampleAppMainMixer.o   -L . -L C:/ide-4.7-workspace/FileIO/arm/a-le-g -L C:/ide-4.7-workspace/BasicSignalProcessing/arm
/a-le-g -L C:/ide-4.7-workspace/ePIAF/arm/a-le-g -L C:/ide-4.7-workspace/MainMixer/arm/a-le-g -L C:/QNX650/target/qnx6/
armle/lib -L C:/QNX650/target/qnx6/armle/usr/lib  -Wl,--rpath-link . -Wl,--rpath-link C:/ide-4.7-workspace/FileIO/arm/a-
le-g -Wl,--rpath-link C:/ide-4.7-workspace/BasicSignalProcessing/arm/a-le-g -Wl,--rpath-link C:/ide-4.7-workspace/ePIAF/
arm/a-le-g -Wl,--rpath-link C:/ide-4.7-workspace/MainMixer/arm/a-le-g -Wl,--rpath-link C:/QNX650/target/qnx6/armle/lib -
Wl,--rpath-link C:/QNX650/target/qnx6/armle/usr/lib    -EL   -g
C:\QNX650\host\win32\x86\usr\bin\ntoarm-ld: cannot find -lFileIO
make.exe[2]: Leaving directory `C:/ide-4.7-workspace/MainMixerTestApplication/arm/o-le-g'
make.exe[1]: Leaving directory `C:/ide-4.7-workspace/MainMixerTestApplication/arm'
cc: C:/QNX650/host/win32/x86/usr/bin/ntoarm-ld caught signal 1
make.exe[2]: *** [C:/ide-4.7-workspace/MainMixerTestApplication/arm/o-le-g/MainMixerTestApplication_g] Error 1
make.exe[2]: Target `all' not remade because of errors.
make.exe[1]: [all] Error 2 (ignored)
Looking like linker in the IDE is so bad that i is complaining about each and every linked library and it requires .o
files to be specified !!! a crude requirement :) ofcourse along with the library !
You need to set the linker search path so that it can find the
libraries.  You may want to consult the IDE documentation.
> http://community.qnx.com/sf/go/post65652
I had set the linker search path in 'linker->Extra library paths' and I had mentioned the library name in 'linker->Extra
 libraries' and even then i was getting the linker error however after specifying couple of object files in 'linker->
Extra object files' for MainMixerTestApplication(application) and MainMixer(library) it is getting built properly.
I am of the opinion that specifying the object files in the project is a crude method. Ofcourse the libraries that are
built are already using these object files and I am specifying these libraries while linking !!!
Any insights how I can get rid of this ?
All -l options should be at the end of the command line. Where is libFileIO.a?
> http://community.qnx.com/sf/go/post65640
Can you list files in your
le-g
Does the library name have "_g" appendded, e.g. libFileIO_g.so ?
If so, you need to add it as "-lFileIO_g".
waveFileFunctions.o
libFileIO_g.a
Makefile
are the threee files in this folder. However when I try to add new library using linker options tab it shows only one
library 'static' and it seems to me that it actually links release version of the library
The issue with the linker complaining about not finding "FileIO" was due
to you trying to link libFileIO.a and you had libFileIO_g.a in your -L
path.
What you are reporting now looks like you are adding both "-g" and
release paths in -L, release being first, and still specifying -lFileIO
which will link the "libFileIO.a" and NOT "libFileIO_g.a". For "_g" to
be linked, you need to specify "-lFileIO_g".
On Mon, 2010-09-06 at 04:24 -0400, Girisha SG wrote:
> waveFileFunctions.o
> libFileIO_g.a
> Makefile
>From the command line you pasted in one of the previous posts, options
you pass to the linker (-L) show that only static libraries were listed
in the search path. Shared objects are in "so-le[-g]" directories.
What are the actual files of your libraries? e.g. ePIAF, what is the
file name (full name)?
On Thu, 2010-09-02 at 07:29 -0400, Girisha SG wrote:
> 1st scenario.
reference to ...'.
> 2nd scenario.
in the 1st example as it is flashing an error in both MainMixer & MainMixerTestApplication). I feel including OBJ file is a crude method.
> http://community.qnx.com/sf/go/post65624
Could be problems with order of the libraries. Do they have circular dependencies?
Yes I have circular dependencies.
How to resolve it and also can you suggest some links to refer to ?
sorry :( ... I have a relook at it but not very sure whether it has any circular dependency or not ... is there any
other possibality also ?
If there is a circular dependency how to resolve it ?
Get rid of it. Either create another library or move some object files from one library to another. Or have just one
library. If library depend on each other there is no point having two of them - because both are always required.
Of cause you can do what you did before - give object files directly to linker but fixing circular dependency is best
option.
> http://community.qnx.com/sf/go/post66063
But is the actual name of the file of your library something like
"libePIAF.so", or literally "ePIAF"?
Extra libraries' and even then i was getting the linker error however after specifying couple of object files in 'linker
->Extra object files' for MainMixerTestApplication(application) and MainMixer(library) it is getting built properly.
> http://community.qnx.com/sf/go/post65824
Library name is something like libePIAF.a but when I add it will take as ePIAF and I have referred to QNX document and
according to that it is proper also as I have explained previously it is getting built after adding some more OBJECT
files to resolve the dependencies.
