Forum Topic - Using -O3 optimization and trying to get a bt : (10 Items)
is this possible if I use -fno-optimize-sibling-calls or something to that affect....
What is the maximum -O level with which I could see a bt and local variables.
I am compiling for ARM ...
Preeti.
Re: Using -O3 optimization and trying to get a bt
> affect....
It should be possible to get a backtrace using -O3. Some local variables may have been removed by optimization so this
might not always be possible.
Ryan Mansfield
-O3 does not give me a back trace ....but -O0 does ... so I needed to find the best option to get bt while I optimize...
Does not give you a backtrace as in no backtrace at all? Or is the backtrace  incorrect?
Does -O2 give you a backtrace? If it lose the ability to backtrace between -O2 and -O3, it might be that the functions
were inlined.
For example:
int a(int x) { return x; }
int b(int x) { return a(x); }
int c(int x) { return b(x); }
int main() {
 return c(3);
With -O3, c is never called. No stack to backtrace
With -O2 or -O3 -fno-inline-functions, a is called but b and c calls are optimized out.
#0  0x08048333 in a ()
#1  0x0804837d in main ()
With -O2 -fno-optimize-sibling-calls, a, b and c are called and therefore we can get a backtrace.
#1  0x08048351 in b ()
#2  0x08048371 in c ()
#3  0x0804839d in main ()
Using -O3 does not cripple GDB's ability to do a backtrace -- better  optimizations just mean there might be less stack,
 or no stack to backtrace.
Which function calls gcc removes is very specific to the code being compiled so generalized statements about how to get
a backtrace at O3 won't be accurate.
Ryan Mansfield
Will -fno-inline help that?
> to find the
> between -O2 and -O3, it might be that the functions were inlined.
> For example:
> int main() {
>  return c(3);
> are optimized out.
> optimizations just mean there might be less stack, or no stack to
> backtrace.
> compiled so generalized statements about how to get a backtrace at O3
> won't be accurate.
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post3072
cburgess@qnx.com
Thanks for the detailed explanation...
I do get a bt but not complete; only one frame ; all other functions are inline ...
so that explains
Let me try -O2 -fno-optimize-sibling-calls
Will update this post with my findings ....
Thanks...
Preeti
so that explains
Thanks...
Preeti
 -fno-optimize-sibling calls gives a compile error : "Invalid option"
I am compiling for ARM ...?
Preeti
Which version of gcc are you using? The -foptimize-sibling-calls and corresponding -fno-optimize-sibling-calls are only
valid options in gcc 3.3.5 and newer. And depending on which version of qcc you are using, you may need to specify -Wc,-
fno-optimize-sibling-calls to have qcc pass the option down to the c/c++ frontend.
Ryan Mansfield
I think we are using 2.95.3
I am basing this on the fact that /opt/qnx630/host/linux/x86/etc/qcc/gcc/default
has DIR=2.95.3$
Also I have a -Wc option specified ahead of -fno-optimize-sibling-calls ....
Meanwhile -fno-inline worked for me...not sure what the difference is between the 2.
Thanks...
Preeti
