Re: Inter operability between RVDS generated object file and qcc generated object file
09/14/2010 9:26 AM
post67157
A. When I compile the sources using RVCT into 4 seperate libraries a, b, c and d (EABI compatible object files are used
for these library generation) and one main application program that uses these libraries, I am able to generte the
executable by statically linking these libraries but when I ran on the target I am getting the following error,
Process 307216 (test.exe) terminated SIGSEGV code=1 fltno=11 ip=00102098(test.exe@_btext+0x1664) ref=0007fff8
Memory fault
B. If I compile each of them as an application I am getting the following errors while linking using ntoarm-ld
1. ..\private\OSAL\QNX\debug_support.c:(.text+0x104): undefined reference to `__aeabi_stderr'
2. ..\private\OSAL\QNX\debug_support.c:(.text+0x124): undefined reference to `__aeabi_SIG_DFL'
3. ..\private\OSAL\QNX\debug_support.c:(.text+0x128): undefined reference to `__aeabi_SIGINT'
4. firC16D16Dec.o: In function `firC16D16DecCh2_32':
..\private\firC16D16Dec.c:(.text+0x5c0): undefined reference to `Overflow'
5. flpOperations.o: In function `db2linear_flp':
F:\RealViewWorkspaces\Workspace\BasicSignalProcessing\Debug/..\private\flpOperations.c:1: undefined reference to `powf'
6. flpOperations.o: In function `linear2db_flp':
F:\RealViewWorkspaces\Workspace\BasicSignalProcessing\Debug/..\private\flpOperations.c:1: undefined reference to `_FLog'
7. iirC16D16O1.o: In function `global_init_IirC16D16O1':
..\private\iirC16D16O1.c:(.text+0x224): undefined reference to `Overflow'
8. C:\QNX650\host\win32\x86\usr\bin\ntoarm-ld: Dwarf Error: Could not find abbrev number 5218.
9. C:\QNX650\host\win32\x86\usr\bin\ntoarm-ld: Dwarf Error: mangled line number section (bad file number).
10. iirC16D16O1S1.o: In function `iirC16D16O1HS1Ch2':
F:\RealViewWorkspaces\Workspace\BasicSignalProcessing\Debug/..\private\iirC16D16
O1S1.c:1: undefined reference to `L_msu_16_32'
iirC16D16O1S1.o: In function `L_mac':
..\private\iirC16D16O1S1.c:(.text+0x66c): undefined reference to `Overflow'
iirC16D16O2.o: In function `L_mac':
..\private\iirC16D16O2.c:(.text+0x2b0): undefined reference to `Overflow'
iirC16D16O2S1.o: In function `L_mac':
..\private\iirC16D16O2S1.c:(.text+0x604): undefined reference to `Overflow'
iirC16D32O1.o: In function `iirC16D32O1':
F:\RealViewWorkspaces\Workspace\BasicSignalProcessing\Debug/..\private\iirC16D32
O1.c:1: undefined reference to `L_mult_16_32'
O1.c:1: undefined reference to `L_mac_16_32'
O1.c:1: undefined reference to `L_msu_16_32'
iirC16D32O1.o: In function `iirC16D32O1Ch2':
meanAryD16.o: In function `meanAryD16':
..\private\meanAryD16.c:(.text+0x200): undefined reference to `Overflow'
C:\QNX650\host\win32\x86\usr\bin\ntoarm-ld: libBasicSignalProcessing_g.exe: hidd
en symbol `powf' isn't defined
(Included the necessary header files while compiling)
11. mmixer.o: In function...
