Forum Topic - mudflap off-line analysis with IDE: (5 Items)
This page describes how to save the memory analysis data to file and analyze it later with the IDE:
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/Memory_Analysis_Quick_Way_To_Find_Memory_Leaks
Can we do the same with mudflap? How?
Mate
Re: mudflap off-line analysis with IDE
run mudlfap intrumented code with mudlfap env vars defined, redirect
output to a file. Upload log to host.
In Mudflap view - click on view menu, Open Log... and select the file.
> Thanks,
> Mate
> http://community.qnx.com/sf/go/post57874
RE: mudflap off-line analysis with IDE
Thanks; sounds simple.
One doubt:   mudflap output goes to the console; will the IDE tolerate
if other log is mixed with mudflap stuff? The memory analysis tool was
letting you to specify an independet output file for the memoy logs.
  Mate
From: Elena Laskavaia [mailto:community-noreply@qnx.com]
Sent: June 25, 2010 10:49 PM
To: general-toolchain
Subject: Re: mudflap off-line analysis with IDE
> Thanks,
> Mate
General
http://community.qnx.com/sf/go/post57888
Yes it will tolerate app output (unless it is badly mixed).
I know it is kind of problem but mudlfap does not have an option for
separating bug output :(
>   Mate
>> Thanks,
>> Mate
>> General
> http://community.qnx.com/sf/go/post57898
Thanks Elena, that should be good; we should be able to suppress other
logs in the worst case.
  Mate
Sent: June 25, 2010 11:47 PM
>   Mate
>> _ Analysis_Quick_Way_To_Find_Memory_Leaks
>> Thanks,
>> Mate
>> General
General
http://community.qnx.com/sf/go/post57910
