Forum Topic - QCC Compiler not working: (9 Items)
From http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/utilities/q/qcc.html , I understand that QCC compiler should
be a built in compiler in QNX Neutrino RTOS but I am constantly getting error as follows:
/bin/sh : QCC: cannot execute - No such file or directory
whenever I try to compile my program using the QCC compiler on terminal on QNX RTOS
Do we have to separately download QCC compiler and if yes please give me the download link
Thanks!
Shashank
Re: QCC Compiler not working
should
What version of Momentics do you have installed? The native self-hosted
tools are only available for x86 and should be available in $QNX_HOST
(depending on how you installed).
Ryan Mansfield
Thanks for your reply Ryan
I have installed Momentics 6.4.1 on Windows but I have not installed it on the Neutrino RTOS. It compiles fine through
the IDE but I want to change my source code and compile it in the RTOS itself w/o needing to switch in the IDE,
compiling and transferring the file through USB to the VMware image of RTOS (as we can't easily transfer files from
Windows to QNX if installed as a vmware image.)
I thought that the command line compiler comes built-in irrespective of whether we install Momentics. Isn't it?
Thanks!
Shashank
Correction: My QNX SDP version is 6.4.1 and Momentics IDE version is 4.6
Shashank
The toolchain is a part of Momentics not the Neutrino RTOS. Together
Momentics and Neutrino form the QNX Software Development Platform (SDP).
The self-hosted QNX 6.4.1 SDP will have the compiler.
Ryan Mansfield
So no compiler in RTOS by itself?
Isn't there anything like "build-essentials" in linux/ubuntu?
Thanks!
Shahsnak
Again, install the self hosted SDP.
http://www.qnx.com/download/feature.html?programid=19608
Ryan Mansfield
Thanks a ton! Ryan
Shashank
Thanks a ton Ryan!
On Tue, Jun 22, 2010 at 6:43 PM, Ryan Mansfield
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post57420
Thanks and regards,
Shashank Todwal
3rd Year |  M.Sc. (Hons.) Physics + B.E. (Hons.) Computer Science
BITS, Pilani - K. K. Birla Goa Campus
+91 9881472930  |  f2007497@bits-goa.ac.in
