Forum Topic - Specifying a stack size causes crash: (9 Items)
If I specify a stack size, I can't even get a breakpoint at _start.  The program crashes immediately.
Looking at the System Summary page, without specifying a stack size, it appears to be set to 8k.
Specifying a stack size of 10k (-N 10K) and after rebuilding everything, the program will crash immediately at startup.
Ideas?
Kevin
Re: Specifying a stack size causes crash
This is QNX 6.3.2, using the 4.2.4 compiler and 2.18 binutils.  Not sure if I have the binutils installed correctly, I
guess that could be part of the problem, but I'm not sure.
Kevin
Just tried building with 3.3.5, and I'm still having the same problems.  I've tried up to 1M for a stack size.
Crazy daisy....
I wonder if it is the invocation of ldrel that is causing problems.
I ran qcc with the -vv option.  ldrel is called when I specify a stack size, but it doesn't seem to be called when I
don't .
Kevin
don't .
Yep, ldrel is what adds the stack note. In 6.3.2 there was an empty
placeholder section for the note in crtn.o but newer binutils will
discard empty sections. I suspect the problem your having is that ldrel
is failing to correctly add a stack size note with the placeholder
missing. Making room for a PT_NOTE segment post link without moving
things around gets kind of tricky. n 6.4.0 we added a default stack note
in the crtn.o files and then the 6.4.0 ldrel will modify the stack note
in place if one exists (all new binaries), or if not (older 6.3.2
binaries), try to create one create a stack note.
If you have a 6.4.0 system, grab the crtn.o files from it (or let me
know which ones you need) and use the attached 64x ldrel built for 6.3.2
and see if that works.
If it doesn't work, can you post the failing binary?
Ryan Mansfield
Attachment: Text ldrel_ 28.47 KB
RE: Specifying a stack size causes crash
Ryan, thank you very much for this information.  I am amazed at how fast you
replied.  Thank you.
I will give this a whirl, probably in the morning.  I'll let you know.
Thanks again,
Kevin
From: Ryan Mansfield [mailto:community-noreply@qnx.com]
Sent: April 13, 2010 19:56
To: general-toolchain
Subject: Re: Specifying a stack size causes crash
size, but it doesn't seem to be called when I don't .
Ryan Mansfield
General
http://community.qnx.com/sf/go/post51620
Hey Ryan,
I'm using a windows host, the ldrel_ doesn't look like a windows binary, can you build one for 6.3.2 windows host?
Kevin
Ryan,
What do I do with the crtn.o file?  Am I supposed to link it against the binary?
Sorry to ask dumb questions....
Kevin
> Regards,
> Ryan Mansfield
Got it figured out, in my over exuberance, I must have overwritten the 6.3.2 ldrel with the 6.4.1.  I reinstalled 6.3.2,
 the 2.18 binutils and 4.2.4 gcc.  All seems to be well now.
Thank you
Kevin
