Forum Topic - ZMQ porting problems ...:
 when I stop gracefully a zmq based application I see the crash below.
What's the problem??
--Armin
(gdb) c
Continuing.
usage: local_lat <bind-to> <message-size> <roundtrip-count>
Program received signal SIGSEGV, Segmentation fault.
0xb826042f in std::ios_base::~ios_base () from /usr/qnx640/target/qnx6/x86/lib/libcpp.so.4
(gdb) backtrace
#0  0xb826042f in std::ios_base::~ios_base () from /usr/qnx640/target/qnx6/x86/lib/libcpp.so.4
#1  0xb84051e6 in __tcf_3 () from /usr/qnx640/target/qnx6/x86/lib/libecpp.so.4
#2  0xb0329445 in __cxa_finalize () from /usr/qnx640/target/qnx6/x86/lib/libc.so.3
#3  0xb83fb624 in _btext () from /usr/qnx640/target/qnx6/x86/lib/libecpp.so.4
#4  0xb840c149 in _fini () from /usr/qnx640/target/qnx6/x86/lib/libecpp.so.4
#5  0xb033dae6 in fini () from /usr/qnx640/target/qnx6/x86/lib/libc.so.3
#6  0xb033dc48 in _do_exit_fini () from /usr/qnx640/target/qnx6/x86/lib/libc.so.3
#7  0xb03294e1 in _cleanup () from /usr/qnx640/target/qnx6/x86/lib/libc.so.3
#8  0xb0329bd7 in exit () from /usr/qnx640/target/qnx6/x86/lib/libc.so.3
#9  0x08048830 in _start ()
(gdb)
What is the reason for that abort??
Re: ZMQ porting problems ...
It's linked against both libecpp and libcpp
On 10-03-24 9:05 AM, Armin Steinhoff wrote:
> --Armin
> (gdb) c
> Continuing.
> usage: local_lat<bind-to>  <message-size>  <roundtrip-count>
> (gdb) backtrace
> (gdb)
> http://community.qnx.com/sf/go/post50319
cburgess@qnx.com
libecpp removed ... all is working now :)
Thanks's a lot !
--Armin
> > Hi,
> > --Armin
> > (gdb) c
> > Continuing.
> lib/libcpp.so.4
> > (gdb) backtrace
> x86/lib/libcpp.so.4
> .4
> libc.so.3
> 4
> .so.3
> > (gdb)
> > General
> cburgess@qnx.com
