Forum Topic - Using mkbuild for automated builds?: (3 Items)
We will use the Windows-based Hudson (http://hudson-ci.org/) application to perform the automated build process.
We use Clearcase for source code control and integrate it into the IDE.
We use Klocwork for static code analysis and also have it integrated into the IDE.
We would like to use mkbuild for automated builds so that the automated build uses the same environment and tools used
by the IDE builds  (IDE is Version: 4.6.0 Build id: I20090510).
We were planning on using QNX C and QNX C++ Projects types for creating new projects from the IDE.
We are only using X86 "debug" and "release" build variants.
What files would we need to include in source control so that projects and workspaces build correctly for our automated
builds?
For each project I believe the correct files (besides the actually source code files and headers) would be:
 .project
 .cproject
 .qnx_internal.mk
 common.mk
 Makefile
 x86\Makefile
 x86\o-g\Makefile
 x86\o\Makefile
Does that seem correct?
What about the Workspace files?
From the looks of it one of them might be:
 .metadata\.plugins\com.qnx.tools.ide.qde.core\qdeBuildInfo
Is that correct?  Are there any others that would need to be maintained under source control?
Thanks in advance!
Rich
Re: Using mkbuild for automated builds?
Sorry, I just realized I posted this to the wrong project.  I've reposted in the IDE project.
Rich
Hi, Richard,
The mkbuild script is intended to be used with an IDE workspace and
requires an IDE installation on your build machine.
The workspace contains an enormous amount of cache data in
the .metadata/ directory that you don't want to maintain in ClearCase.
What you will need to do on the build machine is:
  - launch the IDE to create a new workspace
  - add all of the projects that you need to build to the workspace (use
the
    "Import Existing Projects" wizard for this)
  - in the "Window -> Preferences" dialog, the "General / Workspace"
page,
    check the "Refresh Automatically" option.  Because you will checkout
    the projects before the build, replacing their contents, this should
    ensure that the IDE finds changes to makefiles, .cproject settings,
    etc.
In your build script, make sure that your ClearCase checkout replaces
the projects in their original location on the filesystem.
If you have further questions or concerns, please follow up in the IDE
forum (mkbuild is an IDE automation script, not really a command-line
tool).
HTH,
Christian
automated builds?
>  .project
>  .cproject
>  .qnx_internal.mk
>  common.mk
>  Makefile
>  x86\Makefile
>  x86\o-g\Makefile
>  x86\o\Makefile
> Thanks in advance!
> Rich
> http://community.qnx.com/sf/go/post46052
________________________________________________________________________
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems
