Forum Topic - map file info: (6 Items)
map file info
In QNX4 watcom days, map file could be used to analyze which functions are in source code, but are never used, or if
they are used only locally.
Is there any possibility to get this information in QXN 6.4.1?
Reason: I am making some changes to downloaded code, I and would like to "clean" it as much as possible from remnants.
Regards, PKY
Re: map file info
You can build your application using:
# make CCOPTS="-Wunused-function"
For more warning options you can pass to the compiler, you
can refer to this page:
http://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html
> Regards, PKY
> http://community.qnx.com/sf/go/post44289
Re: map file info
Thanks for quick reply.
But:
- according to the web page mentioned, it's only for static functions
- even if I created a static function, it hasn't reported anything
I have use both
-Wc,-Wunused-function
-Wunused-function
Regards, PKY
> in source code, but are never used, or if they are used only locally.
> > Regards, PKY
> > General
Re: map file info
the warning should be there.
Try "-Wall -Werror"
> But:
> I have use both
> -Wunused-function
> Regards, PKY
>>> Regards, PKY
>>> General
> http://community.qnx.com/sf/go/post44294
Re: map file info
No, it's not reporting anything about unused functions.
> Try "-Wall -Werror"
> > But:
> > I have use both
> > -Wunused-function
> > Regards, PKY
> >>> Regards, PKY
> >>> General
> > General
Re: map file info
You should get warnings like this:
/space/src/foobar/main.c:9: warning: 'unusedfunc' defined
but not used
Try doing this:
# make clean
# make CCOPTS="-Wall" > log 2>&1
and then
# grep "warning" log
to see if there is anything there
If you still don't get any warnings, could you give a sample
source file that shows that?
Aleksandar
>> Try "-Wall -Werror"
>>> But:
>>> I have use both
>>> -Wunused-function
>>> Regards, PKY
>>>>> Regards, PKY
>>>>> General
>>> General
> http://community.qnx.com/sf/go/post44296
