Forum Topic - Code doesn't compile with 4.2.1: (2 Items)
template <class T>
class SharedMemory
public:
	SharedMemory() : m_fd(-1)
public:
	int 			m_fd;
template <class T>
class SharedMemoryCreator : public SharedMemory<T>
public:
	SharedMemoryCreator()
		m_fd = 0;
int main(void)
//SharedMemoryCreator<float> p;
  return 0;
This code compiles fine with 3.3.5 but doesn't with 4.2.1.  The problem is m_fd = 0  for which the compiler says:
error: 'm_fd' was not declared in this scope
I'm not sure if this is a problem with my code not being compliant with latest C++ or if it's a specific QNX 4.2.1 bug.
- Mario
Re: Code doesn't compile with 4.2.1
Hi Mario,
This is gcc 4.2.1 being more compliant to the C++ standard. The C++ parser was rewritten in gcc 3.4 to improve
performance and adhere closer to the standard. The gcc 3.4 changes page contains a list of invalid constructs that were
once accepted and are now rejected.
In your case: " In a template definition, unqualified names will no longer find members of a dependent base (as
specified by [temp.dep]/3 in the C++ standard)"
http://gcc.gnu.org/gcc-3.4/changes.html#cplusplus
You should be able to prefix m_fd with "this->" and be compatible with gcc 3.3.
Please let me know if you have any questions.
Ryan Mansfield
