Forum Topic - strip stripping naked: (11 Items)
We just discovered to our dismay that strip will reset to the default the stacksize and throw away the stack size
specify at link time!
Does that mean I need to use the option --strip-symbol to prevent the info about the stack size to be removed?  What
symbol name should I use?
RE: strip stripping naked
Maybe just put the stack size on the executable after stripping instead
of at link time?
Eg. stack size 512K:
ldrel -L -S 512K <executable>
Sent: Wednesday, November 18, 2009 2:32 PM
To: general-toolchain
Subject: strip stripping naked
the stacksize and throw away the stack size specify at link time!
info about the stack size to be removed?  What symbol name should I use?
General
http://community.qnx.com/sf/go/post42187
Ok nice solution but it`s a real pain because stripping is done when we build the distribution and not at link time.  At
 that stage we don`t know the stack size needed for each executable. Is there any way to read it before stripping?
This is a nasty "bug".
> From: Max Feil [mailto:community-noreply@qnx.com]
> Sent: Wednesday, November 18, 2009 2:40 PM
> Subject: RE: strip stripping naked
> of at link time?
> use?
> http://community.qnx.com/sf/go/post42188
Re: strip stripping naked
Or pass -Wl,-s to have the linker strip?
I normally use strip -g to ONLY strip debug info.
> of at link time?
cburgess@qnx.com
> From: Colin Burgess [mailto:community-noreply@qnx.com]
> Sent: Wednesday, November 18, 2009 2:49 PM
> Subject: Re: strip stripping naked
We don`t want to strip there ;)
That will probably have to do for now.
I`m sure a bunch of people are currently being bitten by this.  I mean stripping is a "standard" procedure when
releasing software no?
> instead
> > of at link time?
> use?
> > General
> > General
> cburgess@qnx.com
> http://community.qnx.com/sf/go/post42190
I`m told doing strip -g ends  up doing the same thing.
> instead
> > of at link time?
> use?
> > General
> > General
> cburgess@qnx.com
Which version of Momentics are you using? 6.3.2? In 6.4.x I wouldn't
expect the note to be strip-able as it should end up in an allocated
section.
There is no symbol for the stack not size.. The stack size is specified
in an ELF note section marked with QNX and has note type 3.
Ryan Mansfield
> From: Ryan Mansfield [mailto:community-noreply@qnx.com]
> Sent: Wednesday, November 18, 2009 2:53 PM
> section.
We tried with strip from both 6.3.2 and 6.4.1 with no difference in behavior (having the default stack size made our
program crashed)
> use?
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post42193
>> section.
program crashed)
No, it wouldn't be a difference in how strip functions. The difference
would be between how the note is created, and manipulated (i.e. linker
and ldrel).
It works as I expected in 6.4.1 but I reproduced the problem under
6.3.2. I'll try to come up with a reasonable solution for you for 6.3.2.
Ryan Mansfield
> and ldrel).
Any update?
> Regards,
> Ryan Mansfield
>> and ldrel).
> Any update?
Sorry, I don't have an update. I've been really short on time lately. I
hope to get to it soon.
Ryan Mansfield
