Issue on 6.3.0 in PtMTrend.h
09/13/2007 2:02 AM
post1136
I had no problems using C++ with the photon libraries so far, except with
PtMTrendAttr_t structure. It is defined as a nested struct and its name
is actually Pt_mtrend_widget::pt_mtrend_graph_info::pt_mtrend_attr.
In PtMTrend.h, there is a typedef that says
typedef pt_mtrend_attr PtMTrendAttr_t;
You probably need conditional compilation or put pt_mtrend_attr in the
global namespace.
I do not know if this was fixed in subsequent releases.
Jonathan Mcdougall
