Forum Topic - Building gcc (6.4.1 release) - missing gmp.h ?: (6 Items)
Trying to build the 6.4.1 release on a self-hosted 6.4.1 NTO machine.
Ultimate goal is to create a self-hosted PPC gcc (all other tools components built OK with minimal tweaking). For now,
just trying to build the nto-x86 version on NTO, so using the nto-x86-o-ntox86 directory
The instructions say 'type make', which I do, and it starts to configure, before complaining about requiring GMP 4.1+
and MPFR 2.3.0,  a need for missing gmp.h, and suggesting various flag options. Then it stops.
What should I be using, or am I missing something ?
Thanks !
Dave
Re: Building gcc (6.4.1 release) - missing gmp.h ?
The instructions are slightly out of date. Starting with gcc 4.3 libgmp
and limpfr are required as host libraries (for cc1/cc1plus). They need
to be configured and installed for gcc to build.
http://www.mpfr.org/
http://gmplib.org/
Ryan Mansfield
RE: Building gcc (6.4.1 release) - missing gmp.h ?
Ah, that makes sense, thanks Ryan.
Would it make sense to check in the tested library code into svn ?
Dave
From: Ryan Mansfield [mailto:community-noreply@qnx.com]
Sent: Mon 19/10/2009 5:31 PM
To: general-toolchain
Subject: Re: Building gcc (6.4.1 release) - missing gmp.h ?
http://gmplib.org/
Ryan Mansfield
General
http://community.qnx.com/sf/go/post40293
Attachment: Text winmail.dat 4.34 KB
Yes we could check the prereqs into the external core-dev-tools repo to
make it easier for people to build gcc. I'll create a PR and put this on
my TODO list. We also need to update the build instructions to include
these instructions. The required versions of gmp/mpfr change with each
gcc release but unless the right version is installed the config test
will fail.
I'm not sure if there has any been customer demand for us to package
GMP/MPFR libraries with the release. If anyone has a need for it
(besides for gcc) please let us know.
Ryan Mansfield
> components built OK with minimal tweaking). For now, just trying to
> configure, before complaining about requiring GMP 4.1+ and MPFR 2.3.0,
> stops.
> http://gmplib.org/
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post40294
Thanks Ryan.
I downloaded those libraries (not sure if I got the right versions). GMP required m4 too, so I grabbed that as well.
M4 built (one minor change), GMP built, but mpfr is not playing nicely - can't find libgmp even when I copy all variants
  from /usr/local/lib to /lib. Also had to copy gmp.h into the mpfr directory to get that going.
No idea how to easily cross-compile them...
So, a pre-tweaked set of these libs would be splendid... In one of those oh-so-rare spare moments... :-)
Thanks !
Dave
Dave Bott wrote:
> Thanks Ryan.
variants  from /usr/local/lib to /lib. Also had to copy gmp.h into the mpfr directory to get that going.
They are both straight forward to cross-compile. You need to use the
--host configure option. e.g --host=powerpc-unknown-nto-qnx6.4.0.
Ryan Mansfield
