Forum Topic - [Q] on build a DLL from static shared objects: (4 Items)
we are trying to build a shared object out of static shared archives only,
but the resulting .SO does not have any exported symbols.
As the S.a archives are all compiled using -fPIC and the functions are global, we would expect that the resulting .SO
will contain the symbols from S.a files - but this is not working.
We tried to use a version script to explicitly declare the functions that should be exported, but it's not working.
So is it possible at all, to generate a .SO out of S.a files only?
are we doing something wrong, or what has to be done that a function from S.a file gets exported from within the build .
SO file?
any suggestions?
TIA
/hp
Re: [Q] on build a DLL from static shared objects
 .SO file?
> any suggestions?
You can use force the entire archive into the shared object using
--whole-archive. Otherwise ld will only pull the required objects from
the archive.
Ryan Mansfield
> the archive.
I did not know that flag, thanks. I also had to add --no-whole-archive after our own libs to avoid pulling in everything
 else, too. It works on the command line if all archives are listed directly. But in our automated build, we use a
linker script file to provide the list of libraries (to avoid running into command line limits). These scripts contain
an INPUT command per archive.
This works fine:
   qcc ... -Wl,--whole-archive liboneS.a libtwoS.a -Wl,--no-whole-archive ...
This doesn't:
   qcc ... -Wl,--whole-archive all_my_libs.txt -Wl,--no-whole-archive ...
where all_my_libs.txt is something like
   INPUT(liboneS.a)
   INPUT(libtwoS.a)
Should --whole-archive also affect the archives listed in the linker script (i.e. "is this a bug?")? Or is there another
 command we could use in the script?
Daniel
>> the archive.
everything else, too. It works on the command line if all archives are listed directly. But in our automated build, we
use a linker script file to provide the list of libraries (to avoid running into command line limits). These scripts
contain an INPUT command per archive.
> This works fine:
> This doesn't:
>    INPUT(liboneS.a)
>    INPUT(libtwoS.a)
another command we could use in the script?
It's a bug. I've filed a PR and I have a fix for it. If you want I can
provide an experimental linker or you can submit a ticket and we can get
an official one to you.
Ryan Mansfield
