Forum Topic - cc: unknown target 'gcc_ntoppc': (4 Items)
I have the craziest thing happening to me.  When I go to compile a project, everything seems to work for the first few
projects and then, after building and linking a few projects, (using taget gcc_ntoppc) it stops and complains:
The whole build session is below.  Any help is greatly appreciated.
Kevin
C:\TestBuild>make all
make -j 1 -Cipl -fMakefile all
make[1]: Entering directory `C:/TestBuild/ipl'
make -j 1 -Cppc -fMakefile all
make[2]: Entering directory `C:/TestBuild/ipl/ppc'
make -j 1 -Ca.be -fMakefile all
make[3]: Entering directory `C:/TestBuild/ipl/ppc/a.be'
../../common.mk:33: EXTRA_INCVPATH:                 C:/TestBuild/include
../../common.mk:34: PROJECT_ROOT:
C:/QNX632/host/win32/x86/usr/bin/qcc -V3.3.5,gcc_ntoppc -c -O -Wc,-mno-fp-moves -Wc,-Wall -Wc,-Wno-parentheses
  -fmessage-length=0 -fdiagnostics-show-
location=every-line -DNDEBUG   -I. -IC:/TestBuild/ipl/ppc/a.be -IC:/TestBuild/ipl/ppc -IC:/TestBuild/ipl -IC:/TestBuild/
include -IC:/QNX632/target/qnx6/usr/incl
ude      -EB     -DVARIANT_a -DVARIANT_be  C:/TestBuild/ipl/copy.c
ude      -EB     -DVARIANT_a -DVARIANT_be  C:/TestBuild/ipl/ppc/image_download_8260scc1.c
ude      -EB     -DVARIANT_a -DVARIANT_be  C:/TestBuild/ipl/image_scan.c
ude      -EB     -DVARIANT_a -DVARIANT_be  C:/TestBuild/ipl/image_setup.c
ude      -EB     -DVARIANT_a -DVARIANT_be  C:/TestBuild/ipl/image_start.c
C:/QNX632/host/win32/x86/usr/bin/qcc -V3.3.5,gcc_ntoppc -c -O -Wa,-I. -Wa,-IC:/TestBuild/ipl/ppc/a.be -Wa,-IC:/TestBuild
/ipl/ppc -Wa,-IC:/TestBuild/ipl -Wa,-IC:
/TestBuild/include -Wa,-IC:/QNX632/target/qnx6/usr/include  -Wa,--defsym -Wa,VARIANT_a=1  -Wa,--defsym -Wa,VARIANT_be=1
TestBuild/ipl/ppc -IC:/TestBuild/ipl -IC:/TestBuild/include -IC:/QNX632/target/qnx6/usr/include      -EB      C:/
TestBuild/ipl/ppc/jump.s
ude      -EB     -DVARIANT_a -DVARIANT_be  C:/TestBuild/ipl/ser8250.c
ude      -EB     -DVARIANT_a -DVARIANT_be ...
Re: cc: unknown target 'gcc_ntoppc'
This is an issue with the recursive mkfiles (-EB option is missing from
the command line). It appears that somehow you are using mismatched
mkfiles and you're using an updated qconf-win32.mk because qcc -a is
being invoked. The 6.3.2 qconf-win32.mk called ntoppc-ar directly
instead of qcc. The -EB option which gets added to the command line
comes from another mkfile so it looks like a combination of new and old
mkfiles are being used.
Can you check to see what your MAKEFLAGS/QNX_TARGEt env variables are
set to?
Ryan Mansfield
Thanks for the reply.  So there appears to be conflict.
MAKEFLAGS=-IC:/QNX640/target/qnx6/usr/include
QNX_TARGET=C:/QNX632/target/qnx6
I need it to be qnx 6.3.2.  I'll change makeflags and see what happens....
Kevin
Ryan,
That fixed it, thank you....
Kevin
